s14 sr20det wiring into s14
fast_s13
alright here it is.. this was done in my 95 240 and it starts up and everything seems to work..you can get a m63 pinout from.... http://www.vadriven.com/eng/M63.html ....
ka pin 1 black/red to sr black/red pin 9 ignition or or startka pin 2 black to sr pin31&32 groundka pin 4 pink to sr pin 4 pink wash swka pin 5 light green too sr pin 5 light green wiper powerka pin 6 light green/black to sr light green/black pin 6 wiper highka pin 7 light green/red to sr pin 7 light green/red pin 7 wiper lowka pin8 brown to sr pin 8 brown wiper off and inter swka pin 9 red to ecu relay power....red wire going to relay on sr plugka pin 10 black/yellow to sr pin35 balck/ yellow iacvka pin11 black/pink to sr pin18 black/yellow fuel relayka pin 17 red to sr pin17 red power ecuka pin 18 brown to sr pin 20 brown power from ign/ sensor powerka pin24 yellow/green to sr pin 44 yellow/green speedometerka pin 26 yellow/red to sr pin46 blue/black tachka pin 27 blue/yellow to sr pin 47 blue/yellow wiper int swka pin 28 yellow to sr pin45 yellow water tempka pin 30 orange to sr pin21 orange celka pin 34orange to sr pin 37 orange/blue start signalka pin 39 green/orange to sr pin 29 green/orange neutral switch
i wired mine up by cutting both plugs off the main harness and wired the ka one into the sr main harness
xdabsx
Car: 96 240sx/92 240sx coupe/94 240sx vert/95 240sx/93 240sx hatch
thanks
TruDynoSports
Car: 1995 240SX SE
Thanks, good info
rms06
Just letting you know, I just tried this wiring on a 95 automatic, and there are issues... The wipers come on when you turn the key on and there is no wiper switch in the car right now. There are a few issues as far as the steps also. On the auto dash harness, there is no wire in pin 9 to give power to the ECU power relay on the SR harness which isn't the big of a deal, BUT look at step 11 (pin 17 ka to pin 17 sr) the wire going to the ecu relay IS in spot 17 and the one that goes to the ECU for constant 12 volt is located in 20 or 21. A little confusing, but none the less...
Okay. fixed the wipers. The japanese harness had the black and brown wires flipped for the US motor. De-pin and re-pin fixes the problem. Also, the wire that is supossed to go into pin 9 on the harness needs to goto pin 16. That's an empty one that gets 12V.
I didn't cut off both of my plugs I just repined the SR plug and added the terminals from the KA harness to cut and solder. I'll post tomorrow once I get the cooling system done, the exhaust system done, and the transmission filled!
Modified by rms06 at 4:29 PM 7/12/2007
Nicen96
Car: 1996 240sx
this is for an s14 to s14 correct because i am having so many problems with my wiring
BoBa524
Car: 1995 Nissan 240SX SE
Nicen96 wrote:this is for an s14 to s14 correct because i am having so many problems with my wiring
that info is not good. none of the colors matched with my s14 sr when i was doing the swap. had to send it away to get done. there is no official wiring diagram write up that does work.
Nicen96
Car: 1996 240sx
who did your wiring harness then boba
BoBa524
dgtldonkey
i agree with boba...i tried to use this and it didnt work at all
Hijacker
Car: '92 240sx Convertible
'94 F-150
I'm amazed that no one found this thread from just a little while ago. I put both pinouts for the dash plug between an S14 SR harness and a '95 USDM S14 chassis.
Nicen96
Car: 1996 240sx
hey hijacker will you give me a color code on the on the s14 sr20det dash plug and are 95-96 the same plug also a color code will be needed for that too thanks very much.
Hijacker
'94 F-150
As far as 95/96 being the same, I won't say yes and I won't say no cause I haven't looked through the '96 manual. More than likely, they're close, but as far as I know, there are some differences in wiring between the two generations.
And what do you want for color code? I have the wire colors listed in shorthand in my notes.
Nicen96
Car: 1996 240sx
ok thanks so much where do i fing 96 240sx se service manual. thanks Jake
Romanuts
Car: 1997 Nissan 240sx
I got a question, has anyone wired an s14 kouki SR20DET into a 97 s14? both zenki and kouki harnessesdo have different colors.
jays240
Car: 240sx
This is not the classifieds. Go post there if you want stuff -Hijacker
Nicen96
Car: 1996 240sx
i am about to do 98 sr20det motor and 96 body
Hijacker
'94 F-150
Do you have a kouki JDM service manual? If so, I'd like to see it. It would be a nice addition to the library.
Nicen96
Car: 1996 240sx
i have the s14 sr20det service manual. thats all i have sorry.
Hijacker
'94 F-150
That's the zenki manual. Just be warned that there will probably be differences in wiring.
Nicen96
Car: 1996 240sx
but that is what i want though right. i have a 96 body and a 98 sr motor
dm-ka
Car: z32tt-sold, '95 S14-sold, '97 S14-sold, another '95 S14-sold.
Current car: Q45
Hey fast_s13 I have a question for you what about the rest of the wires on both plugs, do you just color match those or what do you do with them?
Also I have '95 240 and on mine pin 9 is empty and I have two reds one in pin 17 and one in pin 20.
fast_s13
email me. ill give you my number and try to talk you through it..if nothing else i can come down and give you a hand
sideslider
Car: nissan 240sx
where were u when i did my swap.
fast_s13
i started this thread alomost two years ago
nzmoman
Car: 240sx 2 of em' and always lookin for more
yeah, thats funny....^^^
but I have the zenki SR in a kouki. The pin outs are definitely different, so you kouki guys can't use this. you need the FSM to locate the pins for the wipers. If anything else isn't working its something that I don't use.
dm-ka
Current car: Q45
I emailed you to your email on your profile. Thanks man.
