S14 sr20 water neck outlet on s13 sr20?
White Comet
Car: fc, s13 and mazda6, Sierra
I searched around a little and havent been able to answer my questions, so of course i turn to nico.this is kind of a 2 part question so bear with me. first off:
on my s13 sr20det blacktop, on the upper water neck outlet (the one that dips under the cas) i know there is a sensor thats supposed to go in the top of it. and iirc that sensor is for the ecu. when i bought my car, that sensor was never hooked up. will that effect the way the engine runs and how bad is it to not have it hooked up.
2nd question:
i need a new water neck outlet and i can;t find an s13 sr neck anywhere, just the s14 neck. from what i read, the s14 neck is an upgrade for the s13 neck. is this true? and if the aforementioned sensor is needed, i dont see any spot for it in the s14 neck.
i appreciate any help and if its confusing to anyone i'll try to reword it. thank you
edit- heres a pic of the s14 neckhttp://www.frsport.com/Genuine....html
preludervtec
I'm pretty sure theres no sensor that goes into the upper water neck for either the s13 or s14 SR. Maybe your getting it confused w/ the themostat housing?
The s14 waterneck isn't necessarily a upgrade. But theres a extra port on the waterneck to allow you to connect your turbo coolant line rather than using the one that goes behind the motor. This will make it a lot easier to work on if you ever have any issues in the future.
PhopsonNY
Car: 1989 Nissan 240SX
There is a little info on this page;
Just after half way down might help.
http://www.sr20forum.com/240sx....html
good luck
White Comet
preludervtec wrote:I'm pretty sure theres no sensor that goes into the upper water neck for either the s13 or s14 SR. Maybe your getting it confused w/ the themostat housing?
there was def a sensor in there and a port for it, i'll try and take pics or something. thanks for the info though
White Comet
thanks for that link phopson, i have a question though. is the plug circled in red on the s14 neck pic a port for a sensor or something? if so i might already have an s14 water neck. i'll take pics tomorrow, but this is the plug i'm talking about circled in red
duffman1278
Car: 89 240sx Hatch, the wildcats!
On the S14, and S13, that plug is used as a bleeder screw, to bleed the coolant.
White Comet
oh, ok. it looked too big to be a bleeder screw. thanks
