S14 blacktop in 92 240sx heat shield question.
240soto
Car: 1992 nissan 240sx with s14 sr20det blacktop stock but tuned
So I picked up my car from the shop today and they couldn't change my turbo gaskets etc due to the fact my heat shield bolts were a bit rusty. So I was wondering since my engine is stock, just tuned, do I have to keep the heat shield on for any reason or can I take it off and drive like that, or am I at risk of melting anything. I just want it out the way. Thanks
Lobo240sx
Car: 1991 Nissan 240sx Coupe SR2.35DET Redtop Build
IMO it is important to keep it on. It helps the heat stay on the hot side of the turbo. Taking it off could melt your hood insulation, or the oil drainback hose near the turbo. I'd get some reflector tape and put it where you notice hot spots in the bay.
Hijacker
Car: '92 240sx Convertible
'94 F-150
I haven't had mine on since probably 05 or 06 and never had an issue with the factory turbo. My BMC has never had an issue, my hood insulation is fine, and no paint is peeling or showing signs of heat cycling. I pulled mine because 2 of the bolts snapped off in the manifold, and I couldn't reinstall it securely. If you can try to keep it on, do so.
blkvrtswp
Car: 93 240SX Convertible
SR20DET FP 20G Turbo
You can remove it - we ripped 'em off 50+ swaps and never had any heat problems with a stock turbo.
