evildky »
https://forums.nicoclub.com/evildky-u13100.html
Mon Dec 15, 2014 10:21 am
Actually what is circled appears to be the positive battery terminal and the 2 leads that go to the fusible link box (that little black box on the fender to the left in your pic) all of which attach to the positive side of the battery, the negative battery terminal is resting on your inner fender between the positive lead and the fusible link box. The pic isn't great to verify which battery lead is which follow them to the starter, the negative should go to a starter mounting bolt of bellhousing bolt, the positive goes to a copper stud on the forward end of the starter.
