lol ya thanks but actually I was looking for a good pinout of the white dash plug next to the ecu, right side of the glove box. It's for a 89 240sx hatch, the wiring underthe dash is a mess! and I was going to clean it up. I found one but it wasn't all that clear.... really small lol. so if you got that page it would be so cool.sleepyS14 wrote:oh what the.. it's 2jzswapper from 2jzswap.com!!
hey mann.. ive been goin back and forth with you about my overheat junk on the other forum .. anyway.. good to see you on here.. anything in particular you're looking for.. i have a '91 240sx FSM sitting right in front of me. lmk if i can help.
EDIT:
i assume you mean the cluster pinout and i assume you have a hatch without the HUD.. if you need the other one i have it too.. its on the next pg.
Modified by sleepyS14 at 6:03 PM 11/14/2007
jp, I think it is the F1 connector and yes its for the gauges and such. Right side way up 18 wires total, even thou there isn't 18 wires in it lol. But I appreciate the help, I was able to find some other sources and with a lil luck decifered it from a 91, wires are in all the wrong places on the F1 plug but are still the same colour code! but if you could find one for an 89 sohc one that would be soooooo nice of ya and i could use a pic.... my cam got stolen in vegas, lol never leave stuff even on your VIP table lolsleepyS14 wrote:hmm.. okie.. my '91 was a DOHC..and that '89 is a SOHC.. so i dont knoe if those are going to be the same junk down there. in any case.. is it the pinout TO the ECU ? or something around there.. because theres quite a few things in there ... theres the A/T Control Unit which seems to be above and to the right of the ECU.. the A.S.C.D (Automatic Speed Control Device) .. which is basically the ECU from what i see here.. and this one pinout that's at the top left of the ECU.. which is a pinout that leads to the main harness.. ..
upon closer inspection.. i think this is the one you want because it's the M63 plug.. and the M63 seems to be a plugout of interest to many doing RB swaps and such.. for splicing for correct gauge readings and such.. im going to try to see if they have an M63 pinout guide here.. ill get back to you
EDIT:
okay i have no idea. FAIL!! . perhaps a picture of what you need?
Modified by sleepyS14 at 12:44 PM 11/15/2007
