ARKQX33V6 »
https://forums.nicoclub.com/arkqx33v6-u165721.html
Fri Oct 01, 2010 1:15 pm
Just looked at this thread out of curiosity, and guess what you pique my curiosity. It sounds like you have a multi pak of individual coils. Whether a single big coil or a small direct for specific cylinder the coil has to turn on and off. During the on cycle DC current enters the coil and a field cuts a secondary set of wires. During the off cycle the DC stops and falls back, this collapsing field again induces a current and voltage is added to the point that it is around 20,000 - 50,000 volts but low in amps.
The primary side of the coil if it sees a constant on will induce the secondary very little with the result that the coil will become hot and if not corrected the coil will fail because the varnish on the magnet wire will melt off leaving copper exposed and a shorted coil.
The triggering mechanism may be failing, fast switching transistors. Independent coils use less power than a single coil but switching is easier with the single coil.
Test your coil paks, do not insulate them with tape, remove them 1 at a time and do an ohms check on each, make sure they are all at spec. If your doubtful with things electric, then have some one knowledgeable do the testing.
Dwell time for each coil is built in by a turn on---stay on predetermined time---then turn off and this time varies with speed. A simple explanation is a set of contacts riding a cam and the cam rotates as the speed of the engine...pre electronic cars but with electronics the switching is more accurate, can be variable, solid state and works for a long time without failure, but when failure takes place other items may break down.
If you have a service manual for you vehicle look it up. I do not know what car you have and I do not know what wire. I am guessing the primary side and not the HT secondary side of the ignition coil.
