A forum for approved vendors of specialized, limited-production parts. Help small businesses that cater to Nissan enthusiasts and score some unique, useful parts! Contact greg@nicoclub.com for approval and rates.
S13 Front Strut / Firewall Brace
Postby rotorimp » Tue Aug 07, 2007 9:38 am
Finally ready!
These front strut / firewall braces were designed and engineered specifically for the purpose of increasing the rigidity of the cowl and front suspension areas on the S13.
Developed for the 240sx Convertible, they are equally effective at reducing front end flexion on the Coupe and Hatch, while allowing full access to the top of your engine. Valve cover removal can be done without removing the FSTB.
In addition, they are situated to transfer and distribute strut tower loads evenly across the firewall and bulkhead, increasing suspension flatness.
Manufactured from thick-walled mild steel tubing, with CNC-cut mounting plates and gusseted welds and joints, you won't find a beefier strut brace on the market. PERIOD.
Finish is a high-quality satin black powdercoat that's been professionally applied to resist chipping, scratching and flaking.
Note: Drilling of the firewall (two holes) is required. Installation is fairly simple and should take less than an hour with normal hand tools.
SAY NO TO CRAPPY EBAY STRUT BRACES!!!!
Modified by rotorimp at 7:25 AM 9/15/2007
rotorimp
Vendor
Car: 1967 411, 84 Vanagon SVX conversion, 88 BMW 528e, 66 VW Bug
Re: S13 Front Strut / Firewall Brace (rotorimp)
Postby homeslicej2 » Tue Aug 07, 2007 9:50 am
Is it necessary to reinforce the firewall at the mounting points?
Perpetual student :/
1990 White S13 Hatch
237whp/217wtq @10psi on stock T25 w/NIStune
Weekend fun car/back-up DD
homeslicej2
Car: 1990 S13 SR'd hatch
Postby AZhitman » Tue Aug 07, 2007 10:07 am
No. The steel is fairly thick there, and the forces are distributed with the direction of the firewall metal.
NICOclub on Facebook - NICOclub on Twitter - NICOclub on Google+
PapaSmurf2k3 wrote:Greg could seriously run Nissan.
This site dedicated to the memory of Stacey Lynn Childs 1970-2007 and Martin Childs Jr. 1930-2012
Car: 72 240Z RB25, 63 Bluebird RHD, 63 NL320, 67 WRL411, 67.5 SPL311, 68 510, 79 620, 09 Cube, 99 Frontier, 05 Frontier
Postby Repo Man » Tue Aug 07, 2007 10:50 am
Freaking SCORE! That looks awesome Jason. This just went to the top of my list for stuff for my 'vert. I'll put one on my hatch too as soon as I get the wiring sorted out.
PapaSmurf2k3 wrote:Through the years, I have learned to never question Andy when it comes to 2 things- lifting heavy s***, and drinking beer. Guns comes in at a close 3rd.
Repo Man
Car: E46 coupe, lightly modded. 2003 Z71 Avalanche-parts hauler, hell-raiser.
Postby Loki » Tue Aug 07, 2007 3:19 pm
You have to drill two holes in the firewall to install this right? I'll have to find a means of doing that before I even think about ordering...
S13.V Interior Tear Down/Carpet Replacement
NICOCLUB - Ranked highest in user satisfaction by DJButton and Associates.
Loki
Car: 1994 240SX Convertible
Re: (Loki)
Postby Joe » Tue Aug 07, 2007 4:19 pm
so uh what engine is going in that 240
i see some heavy mount pod modification on the crossmember
Joe
Car: single cam s14, 00 f250 powerstroke, 90 MX83 cressida
Re: (Kamin)
Postby jrivera » Tue Aug 07, 2007 6:20 pm
Very nice...
"All I have in this world is my balls and my word, and I don't break 'em for no one..."
jrivera
Vendor
Re: (jrivera)
Postby DJButton » Tue Aug 07, 2007 8:32 pm
Well Jason, you truly are a master fabricator, finally a strut brace that is better then the others and will fit around my RB before I get a front facing IM! Great Work!
Still in the game and I'm not stoppin. I'm my own now, an still I keep rockin.
DJButton
Car: 2010 Nissan 240sx
Re: (Loki)
Postby homeslicej2 » Wed Aug 08, 2007 1:30 am
Loki wrote:You have to drill two holes in the firewall to install this right? I'll have to find a means of doing that before I even think about ordering...
Would you have to remove the dash to drill your holes and not hit stuff? I like it btw and will have to get after I finish the brake upgrade.
homeslicej2
Re: (homeslicej2)
Postby Silvia_Drift » Wed Aug 08, 2007 1:23 pm
Hey man, I want one. How much shipped to Toronto Canada?
And I am also concerned about drilling the firewall. Do the brake and clutch line need to be relocated? And does it come with the hardware to mount the bar to the firewall?
Modified by Silvia_Drift at 9:29 PM 8/8/2007
Silvia_Drift
Car: 1989 Nissan 240sx Coupe
Postby digzsublime » Wed Aug 08, 2007 2:05 pm
Very nice, I will be ordering one of these soon. I've got an RB and it looks like it should clear.
It's unny though. I was just talking to the guys in our abrication shop, like a week ago, about making one very similar to this. Guess there is no need to use up my favors when I can just buy one. Thanks.
Just out of curiousity, how thick is "thick walled mild steel tubing" ?
When life gives you lemons, SMILE, and throw those fu**ers at someone!
digzsublime
Car: 95 S14 w/ LS1.
Postby Hijacker » Fri Aug 10, 2007 6:27 am
in a few weeks, i shall be ordering one myself. thanks jason!
Hijacker
Car: '92 240sx Convertible
'11 Pathfinder
Re: (tenkawa_akito)
Postby rotorimp » Fri Aug 10, 2007 9:30 am
Hello all,
Drilling the two holes in the fire wall is very easy--you do have to remove the plastic just above it to get to the back side. They can be installed in about 20 min. just because you have to put it on-mark the holes and drill them. Nothing else has to be removed or changed. We did notice with some aftermarket suspension. that you have to lower one of the struts to get it on--just because they are made to very tight tolerances and I didn't want to mess up any threads on the struts. these bars also come very close to the hood. If your all stock you will be fine but some of the carbon fiber hoods come down closer and you might have to put some washers on the hinge. The wall thickness on the tubes is .095" and currently it is up to the buyer for the hardware to attach it to the firewall. Any other questions please post them.
rotorimp
Vendor
Re: (rotorimp)
Postby Jonnie Fraz » Fri Aug 10, 2007 5:23 pm
Nice work Jason. I saw it when you posted up on welding web. On there you mention that there is no interfearance with top mount turbos, is that still the case?
Jonnie Fraz
Vendor
Re: (Jonnie Fraz)
Postby rotorimp » Sat Aug 11, 2007 4:28 am
YES Sir--That was the main reason for builbing them. Seems like there are endless strut bars that go across the motor but none that are able to clear the big turbo's, LS1's ect...
rotorimp
Vendor
Postby Dano » Sat Aug 11, 2007 12:59 pm
I just saw these in person this week and they look great! Now I need to get on the template for S14!
-Dan
1995 240sx - wreck mode | 2005 NISMO Frontier CC - DD hauler
NICOMOM <3<3<3
Dano
Car: '05 Nismo Frontier CC / '95 240sx base
Re: (Dano)
Postby rotorimp » Mon Aug 13, 2007 7:15 am
As of today we have 6 Left.
rotorimp
Vendor
Re: (rotorimp)
Postby datsun2401972 » Mon Aug 13, 2007 6:03 pm
How much do they weigh compared to the competition?
datsun2401972
Car: 90 240sx coupe XE
Postby AZhitman » Mon Aug 13, 2007 9:20 pm
They're significantly heavier than those sissy ebay bars, I'm guessing 5-6 lbs..
FWIW, I can flex a Cusco bar with my hands, and I'm not a real strong guy.
This thing is beefy.
Postby Fenvy » Mon Aug 13, 2007 9:39 pm
will it clear s13 sr20det with 3 nismo mounts?
my cusco barely clears
past: 91 240sx with sr20det, 359rwhp, 325lb/tq
past: 09 g37s 6mt sport, bone stock
now: 05 350z 6mt base, bone stock
Fenvy
Car: 2005 350Z Base 6MT
Re: (AZhitman)
Postby jdm_master_X » Mon Aug 13, 2007 9:39 pm
this is definitely a fine piece of work. i gotta get me one.
jdm_master_X
Car: 92 Nissan 180SX LHD!...LaWL
Re: (jdm_master_X)
Postby rotorimp » Tue Aug 14, 2007 4:15 am
We made them VERY strong--they actually weigh 10lbs. You can NOT twist them by hand. If you look at the pictures they run very close to the fire wall as not to get in the way of any engine combo.
rotorimp
Vendor
Re: (rotorimp)
Postby homeslicej2 » Tue Aug 14, 2007 4:21 am
Do you plan on making more of these (and possibly one for the rear?). I want one, but I have other things to do first.
homeslicej2
Postby ishkabibble » Tue Aug 14, 2007 12:25 pm
Why doesn't it use all 3 bolts on the strut tower?
ishkabibble
Car: 1992 NX2000 hardtop, 1993 NX2000 t-top, 1997 Infiniti I30t
Re: (rotorimp)
Postby datsun2401972 » Tue Aug 14, 2007 6:32 pm
Hopefully you'll have 1 left after the 15(payday).
And please do make a matching rear STB
Looks like the holes would be difficult to drill with the engine in?
datsun2401972
Re: (ishkabibble)
Postby AZhitman » Tue Aug 14, 2007 6:41 pm
ishkabibble wrote:Why doesn't it use all 3 bolts on the strut tower?
Because it's rigid, making it near impossible to install without dropping your struts... Don't want people to damage the threads on the strut studs!
Re: (AZhitman)
Postby Fenvy » Tue Aug 14, 2007 6:52 pm
that makes sense, I was wondering the same thing
Fenvy
Re: (Loveless)
Postby rotorimp » Wed Aug 15, 2007 10:06 am
There was no real advantage to the third bolt. The two bolts properly torqued down are sufficient--plus it gives our bar a unique look.
And Yes as long as there is a demand we will produce them. In fact Dan has me convinced to do a s14 run.
rotorimp
Vendor
Re: (AZhitman)
Postby ishkabibble » Wed Aug 15, 2007 12:50 pm
AZhitman wrote:Because it's rigid
I see. Thanks, Greg, didn't think of installation.
ishkabibble
Re: (rotorimp)
Postby datsun2401972 » Wed Aug 15, 2007 6:47 pm
paypal sent!
Now make a rear one, lol!
Preferably one that ties into the strut towers and the bottom of the trunk!
....please?
datsun2401972
Next
Return to Fabricators' Market
