onosqv »
https://forums.nicoclub.com/onosqv-u507.html
Thu Feb 09, 2006 2:14 pm
Well, as for the flasher location.
You have to remove the underdash panel for easy access. It is a relay box located near the steering column.
You will have to turn the turn signals / hazards on and listen for it. There's about 4-5 boxes down there, so you'll find it eventually.
The one that you unplug that makes the sound stop is it.
Blinking fast doesn't necessarily mean the relay box is not working, it usually means there is a short.
Checked to make sure ALL of your lights are working (i.e. side markers, turns, rear, high mount stop, etc)? Check again, I've had the same thing happen to me. Make sure EVERY light turns on - the taillight, there are 2 bulbs in each light, make sure both turn on.
