xpicer »
https://forums.nicoclub.com/xpicer-u48720.html
Thu Jul 31, 2008 6:23 pm
just run a cable from the relay box off something like the ac , no if you dont have use ac , you can remove that relay and actually use that with some blade connectors that you can get in any parts store or in radio shack , about the thermo switch , the s13 came with it stock mounted on the lower radiator hose , is like a pipe that goes in between the lower rad hose and has a sensor with 2 wires running off it . i recommend sourcing a used one because these can get very expensive in auto parts , last time i ask they run around 180
its the tfs 141 it kicks in at 80 C
