ronnie4 »
https://forums.nicoclub.com/ronnie4-u59164.html
Sat Apr 14, 2012 4:46 pm
Hey guys,
I just bought a 90 with a 92 motor swapped in it. Bought it form a guy who didn't finish the swap and need help putting it together.
It's blowing the main fuse, I believe the circuit is shorting out on the alternator. The positive feed and the ground are bolted right next to each other on the alternator, and my multimeter shows that there is continuity between them. Is the ground wire supposed to be bolted to the alternator? If so, how do I keep the circuit so that the battery feed and ground are separated?
I can post pics of the wiring setup, what's the easiest way to post pics on this forum?
