evildky wrote:"sludge" in an 03? you know the history of the car? someone might have had a small coolant leak and added some bars leak, which will sludge up your whole cooling system and is even a nasty shade of brown, either way I'd start by fluching the system start over clean and check it monthly for odd color changes
I bought the car a little over a year ago from a Nissan dealer. It came with no previous records, although it supposedly passed a 1XX point inspection, which didn't catch the fact that the shifter bushing was shot, as well as the 5th and 6th gear synchros. The tranny blew up less than a month after I bought it, and was replaced along with the clutch under warranty.
I had my 240sx for 5.5 years, and did all my own work, including replacing the timing chain, pulling the engine, replacing the clutch, engine mounts, etc. I'm no newb when it comes to fixing cars. This is the newest car I've ever owned, and I've gotten kind of lazy with checking up on everything. I assumed that there can't be anything wrong requiring a lot of work. I've actually paid to have the oil changed (first time in over 6 years) up until this past weekend.
I had to add some coolant over the winter, as the reservoir was empty, and the heater would blow colder at idle than at higher engine speed. After that I didn't notice the problem until a few weeks ago when I looked at my reservoir tank and then at the radiator.
PS: my 91 240sx (sold to a friend) is still going strong with 190k+ miles. Damn good cars...
Modified by leper421 at 10:16 PM 9/22/2008
