boarder445ushttps://forums.nicoclub.com/memberlist.php?mode=viewprofile&u=113&sid=c86cb5bfe91a5886dfa77baafa52e1d8rotating my tires....Wed Feb 05, 2003 6:15 am
Postby
boarder445us »
https://forums.nicoclub.com/boarder445us-u3960.htmlWed Feb 05, 2003 6:15 am
I have two new front tires and worn back tires... a prelude wants to race me this weekend. So i was going to put the new tires on the rear so that i could get a good launch...
How do i rotate them? left front to right rear and diagonal like that or what... thanks for the help.
Postby
sapix @ RHIT »
https://forums.nicoclub.com/sapix-rhit-u1947.htmlWed Feb 05, 2003 6:15 am
I've always heard you send the fronts straight back, and criss cross the rears when you bring them to the front. I honestly don't think it makes much difference with todays tires. As long your tires are all the same size and not uni-directional.
Postby
sixxdeuce »
https://forums.nicoclub.com/sixxdeuce-u511.htmlWed Feb 05, 2003 6:15 am
I think most of the halfway decent tires made today are uni directional, most tires I see have the direction arrows on the sidewalls. I have heard you are not suposed to change the direction because it can cause the tire to deteriorate because the way the layers overlap. Im not sure if a tire would really fall apart if you ran it backwards.
Postby
mrmotorsports »
https://forums.nicoclub.com/mrmotorsports-u4431.htmlWed Feb 05, 2003 6:15 am
If your tires are directional you can only go front to back. If not you can cross them. Remember this, 80% of your braking and 100% of steering is done on your front tires(unless you have HICAS):) Acceleration is nothing if you can't stop or steer.
