evildky »
https://forums.nicoclub.com/evildky-u13100.html
Sun Aug 01, 2010 12:54 pm
you didn't give the right information to answer the questions you asked, first of all bolt circle, you need 4x4.5" aka 4 x 114.3 , second offset, if you want wide 8.5 and 9" wide wheels, ditch the eibachs and get coil overs, this gives you about 1 more inche of backspace allower for more wheel to tuck under, and even with coil overs 8.5 and 9" wheels in the correct offset will need the fenders cut out and flares added, with coil overs you can fit a zero offset 8" wide wheel with no fender contact, might need a touch of rolling but not much, again thats with coil overs, to get the 8.5 and 9 " wheels you'll need zg flares or similar and the wheels will need to be about a -15 to a -25 offset, and keep in mind when dealign wiht negetive offset wheels you increase scrub radius whihc makes steering taht much harder, as does the increases tire width, but the increase scrub radius on the frotns can cause forweard and rear of the hweel arch contact issues so additional trimming may be necesarry
