StockAsFuhS14 »
https://forums.nicoclub.com/stockasfuhs14-u212206.html
Mon Jan 07, 2013 1:39 pm
So I recently broke a rocker arm on my s14 sr20 blacktop from hitting the rev limiter at 7600. Took the VC off and saw it was number two exhaust side. The rocker was actually broken in half. Right when it happen I drove off the road and didn't drive since. When I took it apart I didn't see any other damage, not even any scoring on the cam lobe. Replaced the rocker and put in Tomei rocker stoppers to stop the problem from happening again. Put everything back together and started it and still the same symptoms, misfire on cylinder 2, tapping sound. Vacuum reading is right where it is normally so I don't think my valves are bent. I've been told that the lifter bleeds down without a rocker being in place for a long time (10 days for this case) and that they take time to refill with oil. I've ran the car for a total of 5 -8 mins and still the same. I even tried just cranking it without the injectors plugged in for 10 second periods every 10 mins for about 40 mins and still the same. I've been told that maybe a shim adjustment is in order for that lifter, but the lifter I installed was 100% brand new so I figured it degas more material than my old rocker and would be ok with the same current shim. If anyone could shed some light on this it would be appreciated.
