Sushibandito »
https://forums.nicoclub.com/sushibandito-u133627.html
Sun Feb 21, 2010 1:59 pm
Necro-posting but I wanted to get some input before I drop $150 on unnecessary parts. My wheel vibrates fairly aggressively at or above 60 mph. I've tried testing it at up 90, same amount of vibration. I don't remember really what it was like when the car was stock, so I can't pinpoint if it was something changed since then.
I have new Tein tension rods, I don't know if this would contribute to a more direct "road feel" situation. Vibration is just as bad as it was on stock suspension, it now has KYB GR-2's and Tein S-Tech springs. I had the tires balanced, the right front tire was off by 2, pretty sure it was off by 2 lbs, but maybe 2 degrees, can't really remember.
So the next most likely problem is blown tie rod bushings, right? Is there a way to identify a bad bushing? Tension rods were easy, its a big crack in the rubber, but from tie rod pictures, it seems more complicated to determine if it has gone bad
OEM or aftermarket? Tein inner + outer rods are running about $150, better brand than that? Or are the Tein ones really only meant for drifters ie improved steering angle? Which I don't really need, I doubt this car will be seeing the track
