Shocks, springs, sway bars, coliovers, bushings, brakes, rims, tires - You name it, this is the spot to discuss Altima suspension modifications!
Review: BC Racing BR Type Coilovers
Postby Loop » Sun May 03, 2009 3:13 pm
First and foremost, I want to thank BC racing for getting these coilovers out to me as quickly as possible. I want to thank Tristan @ BC racing for answering all my emails. Awesome customer service!
Initial impressions: These came very nicely packaged and nothing was damage inside. It is protected by bubble wraps and cardboard materials. When I took these out of the box, first thing in mind is a very high quality built and how pretty these looked. It’s a strong, heavy, and thick built. Looks way more solid than the OEM ones. Also includes your brackets for your brake lines and ABS.
Driving impressions: Hands down way better than my Eibach spring w/ OEM shocks. I had my setting to 15 fronts and 10 rears. The ride felt smoother, much better handling, and less harsh than my Eibachs with the settings I had. I have only used this setting so far, but I will be updating my thread later on when I test out all the settings. Personally I like my ride stiff.
Handling: I love this part about the BC racing coilovers. It handles amazing. Cornering on turns couldn't be more fun. It’s just sturdier and less body roll.
Noise: The noise did increase a little, but I was going to expect this when you have pillow ball mounts. You are having metal on metal. I will be re-tightening everything to see if this can be completely eliminated. Though this isn't too much of an issue for me because in the end you’re having better performance.
Price: Best bang for your buck with all the features it has. Don't miss out the group buy that Circuit Motorsport is having!
Installation: Very straight forward, fitment is great. I only had one issue and that is the locking nut they provided for the rear which were a little too big. So I went to Lowes and bought the right locking nut size for only $4 for 2, one on each side. I will be mentioning this to BC racing to make sure they fix this small issue.
Dampening: Love it. 30 way adjustable for fine tuning. You can feel and hear the clicks to know which one you are on. It only requires counting and turning the knob. Very simple to do.
The only problem is when you want to do the rear dampening; you are going to need to jack it up so you can fit your hand. It’s definitely not BC racing fault for doing this, it is how Nissan built the Altima because you have no access to the rear strut from the trunk. Which would have been easier since you could of just pop the trunk and adjust it from there.
Front camber adjustments: Definitely a bonus feature! I have not tried this, which I will need to do because of my aggressive wheel setup I have. In order to do this, you are going to have to do it before hand because you have very limited access when it’s installed. Here is a picture of what I mean:
Ride height adjustability: I did not adjust mine and used the settings it came from the factory. Definitely has potential to be lowered more and go back to stock height. You can adjust these to your style. This isn't hard to do, you will need to take off your wheel and use the supplied wrench BC Racing gives you. Follow its instructions for proper lowering or heightening. The reason why I haven't adjusted mine yet is because I am letting it settle and I can go from there. Even without adjusting, it is lower than my Eibach springs still. Which I will be showing pictures later on this post.
Current gap measurement:
Front
Rear
Eibach:
BC Racing:
Pictures:
Note: Take in consideration that I have reduce weight going on.
Tein SS | Stillen | Rotora BBK | Forgestar | Kumho MX
Injen | Borla | Sun Auto | Rays | Ichiba | Kics Project
Loop
Car: 08 Altima Coupe SE
Re: Review: BC Racing BR Type Coilovers (Loop)
Postby bunda4th » Sun May 03, 2009 4:34 pm
Very nice. I wish I had money now...
Can you take a picture of it from the back so we can see how much contact the tire get to the ground.
Those look nice and your car is awesome!
What size wheels/tire combo are you running?
Also do you know if you will rub or not if you go a bit lower as in you drop it to make it flush. (no gap between fender/tire)
bunda4th
Car: 2008 Nissan Altima Coupe 2.5S 6MT
Re: Review: BC Racing BR Type Coilovers (bunda4th)
Postby nordy » Sun May 03, 2009 5:05 pm
Wow! Pure Sex...
Ive ordered and can't wait
nordy
Car: M35 Sport
Postby LongBeachCoupe » Sun May 03, 2009 5:08 pm
Ohh come on LOOP!
They look great, but I thought youd crank em down all the way just to show us the "low life"!
LBC Overlays are HERE! INSTOCK & $32 DELIVERED!
20" ADR Propulsions-SurmanM Custom Dash Cluster -Racingline Front Strut Tower Bar-SBD Grounding Kit-Stillen Lightweight Pulley-Stillen RSB-Xentec Heads n Fogs- Chrome Signals -Fiberglass Eyelids - Eibach Pro-Kit- Fujita WAI - Nismo CatBack - 15/5% tint - Red LED Interior
LongBeachCoupe
Postby legend_217 » Sun May 03, 2009 5:26 pm
Loop ! Do you have to take out your Eibach pro-kit and put oem springs on when you install BC coilovers ?
AEM intake, Nismo exhaust, LED taillights, LED strip, Racingline endlinks, strut bar, Eibach pro-kit, 18's Konig Trouble,Projector headlights, Grounding kit, Stillen Pulley, swaybar, Valentine one 1.7
legend_217
Car: 08 Altima Coupe 3.5 black
Re: Review: BC Racing BR Type Coilovers (legend_217)
Postby LongBeachCoupe » Sun May 03, 2009 5:37 pm
legend_217 wrote:Loop ! Do you have to take out your Eibach pro-kit and put oem springs on when you install BC coilovers ?
Unless im missing something BIG here lol... you take ALL springs off, OEM, Eibach, H&R.. whatever!
See those Black curly things, those are the springs for this!
LongBeachCoupe
Postby hamandbacon » Sun May 03, 2009 5:56 pm
you must not know a lot about how cars work..
hamandbacon
Re: Review: BC Racing BR Type Coilovers (hamandbacon)
Postby LongBeachCoupe » Sun May 03, 2009 6:08 pm
Ham he had me second guess myself for a minute!
A little knowledge that I used to educate myself after royally screwing up my car in Forza 2 lol....
So, what are coilovers? Most people know they're expensive, race cars use them, they're expensive, some show cars have them, Loop has them, and they're expensive! (But everyone's talking about them!)
In the simplest definition, coilovers replace the stock shocks, struts, and springs on a vehicle and enable ride height and weight distribution to be adjusted with minimal effort. (simple enough..)
Most coilover systems also allow shock compression rates to be altered through the turn of a knob like these BC ones. One of the best features of coilover systems is how easy they are to install many manufacturers ship their coilovers pre-assembled. But there has to be more to it, right?
Coilovers were designed with the racetrack in mind and performance as a primary concern. Through the use of scales that measure the amount of weight each tire supports, coilovers can be manipulated through compressing and uncompressing springs to give the vehicle more desirable weight distribution. No problem, right? This straightforward concept turns more complicated when a specific weight distribution is desired. Unless your tracking the car hard, just think of Forza 2 lol.
During cornering, weight transfers across the chassis diagonally. In other words, when entering a left-hand turn, weight travels from the left-rear to the right-front of the vehicle. This fact also holds true when adjusting coilover systems to achieve a desired corner weight. For simplicity's sake, we're going to use an example utilizing a Utopian car weighing 3,000 pounds. We're also going to discount the driver's weight and assume the car is perfectly symmetrical. By putting the car on scales that weigh each corner of the vehicle, we see that the left-front weighs 950 pounds, and the right-front weighs a similar 950 pounds. On the rear, both the left and right weigh 550 pounds.
Plain and simple, corner weighting is a difficult task that is time consuming (And did I mention difficult?). The process is so complicated that you must actually use some of the knowledge you attained in your advanced placement physics class in school. The concept is fairly straightforward, but the actual practice will kick your butt.
As I said, weight transfers diagonally, so the coilovers must be adjusted with the knowledge that when you adjust the right-front, the left-rear will be affected, too. But it doesn't end there. Let's say, for instance, that the right-front coilover spring is lowered....
What affect will that have on the left-rear? When the spring collar is lowered, the weight resting on that corner will decrease. The weight resting on the diagonal wheel will, more often than not, decrease as well, but the weight resting on the other two wheels will be force-increased, depending on the chassis design. Each adjustment affects every corner, and that's why the process of corner weighting gets so immensely complicated.
In our hypothetical example, if we wanted to decrease the weight on the right-front wheel, the spring collar should be lowered. The weight on that wheel would decrease beneath 950 pounds, the diagonal wheel should decrease beyond its resting 550 pounds, and the left-front and right-rear resting weights should increase accordingly, as there must always be a constant weight pushing on the ground in a stationary car. A lot of little adjustments must be made at each corner, and detailed records must be kept in order to find out what worked and what didn't and by how much.
LongBeachCoupe
Postby Loop » Sun May 03, 2009 6:37 pm
bunda4th wrote:Very nice. I wish I had money now...
I still need to do an alignment, but I can still get a picture up within a few days.
Wheel setup: 19x9 +29
Tire setup: 245/35/19
I have stretch tires.
If you have the right wheel/tire setup you shouldn't rub if your looking for that slam/flush look. Since my setup is aggressive, I will need to camber the front since it seems to be sitting at zero. With the camber adjustment built into the coilover, this will be easy to fix. The rear has a natural negative camber, a little less than the Eibach, and I will be rolling my rear fenders just in case if the camber needs to be corrected.
Loop
FN-QR
Postby LongBeachCoupe » Sun May 03, 2009 6:43 pm
Vin, check this Link
Do you think you can do what they did to the g37 so you can adjust the rear with ease?
LongBeachCoupe
Re: FN-QR (LongBeachCoupe)
Postby Loop » Sun May 03, 2009 6:51 pm
Are you talking about the rear dampening extender? If so, you are block off from doing that. BC Racing seem to redo the design because of that. Take off the trunk carpeting and you will see why.
Modified by Loop at 11:59 PM 5/3/2009
Loop
Re: FN-QR (Loop)
Postby LongBeachCoupe » Sun May 03, 2009 6:54 pm
Doh! I was just taking a stab at it for you!
LongBeachCoupe
Postby FGFCacoupe » Sun May 03, 2009 6:54 pm
Viscious stance. Cant wait to see it slammed more
FGFCacoupe
Car: Super Black 2008 Nissan Altima Coupe 3.5 SE
Postby nnguyen » Sun May 03, 2009 7:30 pm
great review! ill be sure to order mine from modern racing soon.. since i like local.
One question tho, how would one go about adjust the camber in the front since it block? Do i have to take off the whole assemble?
And thanks again for such a great review! slam it! lol.
nnguyen
Postby windex » Mon May 04, 2009 2:41 am
Great review loop! One question though... What size is the locking nut that you had to buy?
Mods: Injen Intake | Stillen Full Cat-Back Exhaust | Eibach Pro-Kit Springs
windex
Car: 2008 Altima Coupe 3.5SE
Re: Review: BC Racing BR Type Coilovers (windex)
Postby Circuit Motorsports » Mon May 04, 2009 6:02 am
Awesome review, car looks great!
If anyone has any questions on these or just wants to place an order through us just shoot us an email - sales@circuitmotorsports.net
Get in on our group buy!
Modified by Circuit Motorsports at 12:57 PM 5/8/2009
Circuit Motorsports - "Affordable Performance"
Email - sales@circuitmotorsports.net
AIM - circuitms
Site- http://www.circuitmotorsports.net
Circuit Motorsports
Car: GT-R
Postby desertdragon » Mon May 04, 2009 8:28 am
Hey Loop, do your front tires sit flush with the fenders? or do they stick out about 2 mm?
Thank you in advance.
[Mods: Tint: 5% back, 35% front; Eibach Pro kit springs; Volk racing RE30 18x8 with Dunlop Direzza DZ101 245/45,18; STILLEN Cat back exhaust; STILLEN rear sway bar; STILLEN hood dampener, Racingline STB.
desertdragon
Car: 2008 Altima coupe 3.5 SE with CVT Winter Frost
Postby legend_217 » Mon May 04, 2009 8:42 am
That's why I'm here. lol
legend_217
Postby akamaru » Mon May 04, 2009 9:19 am
nice Loop
really nice
cant wait to get these babies~
-Dark Slate08 Altima Coupe 3.5se
CVT-p+t package
Injen Intake
5 windows Tinted 50% fronts 10% back lil windows 20% rear window
white led plate lights
blue interior lights
Greddy ti-c exhaust
led tail lights
coming soon:
tower n sway bars, coilover
akamaru
Car: Altima coupe 3.5se
Postby One Crazy Max » Mon May 04, 2009 11:56 am
it looks very nice loop.
did the wheels end up looking more flush?
how heavy are they compared to stock, and by the looks of them they seem to be very high quality.
i think im going to be getting these for the summer.
**Fujita SRI** 14.225 @ 100.00mph w/2.207 60ft, 90F, 60% Humidity
One Crazy Max
Car: 2007 Nissan Altima 3.5SE 6MT
Postby toxik » Tue May 05, 2009 4:18 am
Loop wrote:
lol i have a dirty mind
hehe nice loop
09 370z Pearl White - touring/sport
toxik
Car: 09 Pearl White 370z
Re: (One Crazy Max)
Postby Jose3.5 » Tue May 05, 2009 9:01 am
My buddy ordered these for his sedan and should be getting them this week
2007 Altima 3.5 SE
Jose3.5
Car: 2007 Altima 3.5 SE
Re: (Jose3.5)
Postby akamaru » Tue May 05, 2009 9:15 am
lol i have a dirty mind too
LOL
akamaru
Re: (Jose3.5)
Postby PhEnoM78 » Tue May 05, 2009 9:20 am
wow i wish i had the money to do this.....but i dont so yea........guess the eibachs will be the new f/s item on here lol
PhEnoM78
Car: 08 altima coupe 2.5 mt
Postby Loop » Tue May 05, 2009 6:55 pm
Thank you all. I will respond shortly to your questions.
Loop
Re: (nnguyen)
Postby Loop » Tue May 05, 2009 7:14 pm
nnguyen wrote:great review! ill be sure to order mine from modern racing soon.. since i like local.
Make sure they are a authorized BC dealer and that they actually have these in stock. These are going to be hard to get since they just came out. Very limited production at the moment.
I am not to positive on the front camber adjustment. It looks like you are going to need to take off the entire coilover due to limited access. I would ask BC Racing or CMS if you have questions.
windex wrote:Great review loop! One question though... What size is the locking nut that you had to buy?
I am not 100% what is the correct nut size since I bought the wrong size myself. I believe it is m12x1.25 though. I will know soon when I get my new bolts from Nissan.
desertdragon wrote:Hey Loop, do your front tires sit flush with the fenders? or do they stick out about 2 mm?
They are directly under my fender LOL. I need to camber my front so I can lower it more.
One Crazy Max wrote:it looks very nice loop.
The front went back to its stock camber from it looks like. The rears actually look more flush, but I will need to roll my rear fenders for a more flush look.
Sorry, I am not sure about the weight.
Loop
Postby theoctopussi » Wed May 06, 2009 1:49 pm
what's the link to get these?
MODS: Debadged, Straight Pipe Exhaust, Xentec 5000k HIDs Lows, Flat Black Stillen Short-Ram Intake.
If You're Not With Me You're Behind Me,
Lucciano Eslao
CEO/Artist/Skater
http://www.theoctopussi.com
myspace.com/octopussi
twitter.com/octopussi
theoctopussi
Car: 2008 Altima Coupe 2.5 6MT
Re: Review: BC Racing BR Type Coilovers (theoctopussi)
Postby Loop » Wed May 06, 2009 4:34 pm
theoctopussi wrote:what's the link to get these?
Circuit Motorsport is having a groupbuy for these coilovers on NICO!
Link: http://forums.nicoclub.com/zer...axima
Loop
Postby akamaru » Fri May 08, 2009 9:30 am
Loop, is there any squeeking noises from the coil?
and have u tried to go over speed bumps?
akamaru
Postby nnguyen » Fri May 08, 2009 10:24 am
nnguyen
Re: Review: BC Racing BR Type Coilovers (akamaru)
Postby Loop » Sun May 10, 2009 3:16 pm
akamaru wrote:Loop, is there any squeeking noises from the coil?
No rattles or squeaking. Everything is good, make sure to torque the bolts to its recommendation and preload the rear.
Loop wrote:I am not 100% what is the correct nut size since I bought the wrong size myself. I believe it is m12x1.25 though. I will know soon when I get my new bolts from Nissan.
Okay, I just confirm it is m12x1.25 locking nut. BC Racing should be supplying the correct locking nut size for feature kits or even the up coming kits. If not, they are really cheap, I got another 2 locking nut for 98 cents from King Bolt.
Loop
Postby mcheddadi » Thu May 14, 2009 9:56 am
sent you an email
mcheddadi
Car: Porsche Cayman S
Re: Review: BC Racing BR Type Coilovers (mcheddadi)
Postby Loop » Thu May 14, 2009 8:44 pm
mcheddadi wrote:sent you an email
Cool, I will reply back this weekend.
Loop
Postby Rob.Vegan » Thu May 14, 2009 10:11 pm
BEAUTIFUL
Now decision time...
Canon 30D
or
BC coilovers
Click on car pic to see Mods list
Get your LBC Head & Tail Overlays HERE
Rob.Vegan
Car: 08 2.5S Altima Coupe 76 Datsun 280z (not running)
Postby mcheddadi » Fri May 15, 2009 6:02 am
moo moo farm
Modified by mcheddadi at 11:14 PM 5/15/2009
mcheddadi
Postby michaelthepsycho » Sat May 16, 2009 3:43 am
After looking at these I think everything is top notch but there's one final issue with the wheel gap: the left and right of the wheels. It's time for you to step up and prototype some kind of extender kit (OR a whole NEW kit) to eliminate the gap.
Since you have the ED kit, maybe you can get them to... Extend the bumpers, side skirts, and fenders a little bit?
Or just get more tire to fill the sides.
michaelthepsycho
Car: 09 Maxima S
Re: (michaelthepsycho)
Postby Loop » Sat May 16, 2009 9:08 am
michaelthepsycho wrote:After looking at these I think everything is top notch but there's one final issue with the wheel gap: the left and right of the wheels. It's time for you to step up and prototype some kind of extender kit (OR a whole NEW kit) to eliminate the gap.
If you read my review, I explained why it's not drop. These coilovers are fully adjustable. You can adjust these to your style. i.e slam or stock height.
Take consideration that I have a good amount of reduce weight on my car(in-cabin and exterior) and my tires are stretch thus sidewall is a bit smaller.
Loop
Re: (Loop)
Postby hamandbacon » Sat May 16, 2009 12:41 pm
stretch tires is the way to go these days
hamandbacon
Postby mcheddadi » Sat May 16, 2009 1:25 pm
Don't want to be pushy or anything, but I'm waiting for your words before ordering these man
mcheddadi
Postby mcheddadi » Sat May 16, 2009 2:41 pm
thanks for the reply Vincent!
mcheddadi
Next
Return to Altima Suspension, Brakes, Rims and Tires
