Rev Limiter on a 93 240sx??? 5500 rpm??? True or NOT?
Hybrid-JD
i was just checking out the 1993 240sx today and i was just taking the guys car for a spin. tried to redline it but it wouldnt let me pass 5500 rpm?
is there a rev limiter on a 1993 240sx?? is there anyway to get rid of that limit?? and does anyone konw where to get this fixed?? i wanan get the car ..but not sure how i can by pass this problem?
anyone on the fourm h ave the same thing? please share your experiences!
Jimmy
spec-v5150
My friends 90 S13 does that. It was rebuilt and it would hit the rev limit at 5500. He tried another ECu (mine) then a tuned ECU and nothing. He tried a bunch of crap and his limit is still at 5500. Someoen told him to check the valve springs but we never did.
So I am not saying that it does that because it was rebuilt but....who knows.
Hybrid-JD
then for sure its a malfunction and its NOT stock!!
not getting the car anymore!! hahaha
spec-v5150
LOL yeah...I beleive the real rev limit is 6500 or 6200. BUt honestly...the KA (at least the Altima) dies off after 5500 or so. NO POWER. So really it isnt that bad.
groundhogday1976
Car: 2015 Altima 2.5 S
My '93 has a redline of like 6800, rev limiter kicks in at like 7100.
nismokid
the rev limiter in the 240 will only kick in at 5500rpm in fifth gear other than that you can take it up to 7100rpm
groundhogday1976
groundhogday1976 wrote:My '93 has a redline of like 6800, rev limiter kicks in at like 7100.
Actually, now that I look at it redline is at 6900. If your rev limiter is kicking in at 5500 in first, I think something's wrong.
p00t
there are 2/3 limiters on the 240sx.
1. gear limiter - when in 4th or 5th gear, a sensor is triggered for each of those gears which sends a signal to the ecu. the ecu says " ok this ****er is doing 5500rpm in 4th gear which is insanely fast, this is where his fun ends"
how to remedy this problem? unplug the 4th and 5th gear sensors on the transmission. problem solved
2. speed limiter - i have personally never hit this even when going past the speedo range.... but some people claim its there (maybe autos only??? dont quote me plz :oface) , ecu sees 115-130mph and it cuts it. only way around this if it exists is to cut the speed sensor to ecu wire, but when u do this you lose your speedo.
3. rev limiter, as soon as you hit 6900-7100 rpm the ecu comes to the rescue and saves your poor, overworked, mistreated KA, and cuts fuel. if your insane and want to blow your engine up on purpose you might be out of luck. only aftermarket/retuned ecu will lift this limit.
Q45tech
All Nissan ecu have both rev and speed sensors and hard and soft limiters ............on most the hard [fuel cutoff] is 6900 rpm.
The speed limiters are set with the speed rating of oem original tires. Except the Q and TT 300zx which were 155 mph for reinforced V rated tires.The speed and rev limits can be changed by reprogramming ecu [JWT] on OBD1 engines.
Trppen37
Car: CA18DET
Spec V you are wrong my rev limiter cuts at 5k !
