Retrofit Source XB Led Fogs Installed
speedracervroom
I modded my 08 bumper with a 2014 Aero bumper. Been without fogs for sometime because i didn't want to run stock. Finally found these XB Led fogs and have heard nothing but good things about. They fit perfect just have to make a bracket. Wires are plug and play. The cut offs are amazing and super bright (brighter then HIDS ) here is a pic of them installed. Just wanted to give the Y51 guys another option that works for the car.
DoN_BLaZe34
Car: 2007 M45 Sport - Sold
2006 FX45 - Traded
2014 Q70S 5.6 - Sold
2017 Q70L 5.6 - Current
Looks good, need some pics of them on along with the cutoff.
Also the fogs for the Y51 are H8's instead of H11's like the Y50's, so we'd have to account for that.
Ilya
These fit in the stock location? Or did you have to alter the bumper?
Also, these are the ones you bought, right?
http://www.theretrofitsource.com/led-li ... ype-s.html
Please post some pictures of them on/cut off, etc. Also, a quick HowTo of how to remove the stock fog lights, etc. if you can. Thanks!
DoN_BLaZe34 wrote:Looks good, nice some pics of them on along with the cutoff.
As for H11 vs H8, the harness is the same, it's just the bulb that is different. These should plug right in to our harness since we don't have to worry about modifying the bulb (see here),
wideopn11
Car: 2012 Infiniti M37x Moonlight White
Takeda CAI
Stillen exhaust w/ MeganRacing Y-pipe
SCALE coilovers 16K/10K F/R
Akebono BBK
Cusco strutbar
25mm spacers F/R
Uprev tune by seymore4
Nice! Yes more pics please and any write up or instructions of what you did, how you did it...would be very helpful.
speedracervroom
yes direct fit just can't use the brackets that come with the fogs. Here are some pics of the make shift mount i did. looks ugly but it works.
The ones i bought.
http://www.theretrofitsource.com/led-li ... HQbr4s-BE4
Ilya
Thanks!
wideopn11
Takeda CAI
Akebono BBK
Cusco strutbar
25mm spacers F/R
The mounts look fine, and besides, it's on the inside of the bumper that no one will ever see. Great job.
Is that light beam pic from just your fog lights? It looks kinda high off the ground for fog lights or is your driveway sloped?
Panzer Leader
Car: 2012 M37S; Formerly owned a 1994 Infiniti J30t and 93.5 G-20.
Are the lenses plastic or glass? What was the cost? Thanks.
wideopn11
Takeda CAI
Akebono BBK
Cusco strutbar
25mm spacers F/R
Panzer Leader wrote:Are the lenses plastic or glass? What was the cost? Thanks.
Check out the link provided for the bulbs.
$160
TECHNICAL
LEDs3x Philips Luxeon T (3W)
LumensApproximately 1200/lamp
Kelvin5000KInput12V or 24V
ConnectorH11 Male Input
Water-tightnessIP67 waterproof
LensUV resistant High Impact Polycarb
BodyAluminum w/ heatsink
speedracervroom
That cut off pic is the fog off the bumper before install.
AJ170
Is there any way we can bring these pictures back to life? One of my fog lights housing is broken and I was looking at replacing them with these but I'm not sure what will need to be done, like what does making a custom braket entail? Could I pay a body shop to install this? Will I need to contact someone who does cnc and order a special metal braket???
Ilya
Unfortunately there isn't as people are able to use a multitude of methods of sharing photos. Not something that is done via NICOClub.
