General discussion area for the Altima Coupe. Sponsored by: Racingline Performance
Reset Airbag light?
Reset Airbag light?
Postby thefarewellnote » Fri Apr 04, 2008 6:46 am
I recently had an AVIC d3 installed in my car and since then the car's airbag light has been flashing non stop. THe installer told me that it just need to be reset either by myself or by the dealer.
Anyone know how to reset it
Thanks?
thefarewellnote
Re: Reset Airbag light? (thefarewellnote)
Postby rjdmmfl1 » Fri Apr 04, 2008 7:18 am
thefarewellnote wrote:I recently had an AVIC d3 installed in my car and since then the car's airbag light has been flashing non stop. THe installer told me that it just need to be reset either by myself or by the dealer.
Thanks?
yes, its on the forum, but would take a bit of searching to find... I suggested that our moderator Tyler place this info on the Read First page but......
push the ignition from OFF to ON
the air bag warning light will appear for about 7 seconds and turns off.
then push igniition switch OFF immediately.
after ignition switch is turned OFF, wait for about 6 seconds.
after you REPEAT THE PROCEDURE 3 TIMES, push the ignition switch ON, this time the ABS warning light has been reset.
step on the brake and push the button to start the car. turn the ignition off and start the car. Hope this will help. I did this procedure to my car and it works.
rjdmmfl1
Car: 2008 Altima Coupe, Radiant Silver, 3.5SE, Premium Package, VDC
Re: Reset Airbag light? (rjdmmfl1)
Postby SHIFT_COUPE » Fri Apr 04, 2008 1:50 pm
It's there now!
-Tyler
Borla Exhaust, Racingline Y-Pipe, Racingline Strut Bar, Racingline Short Throw, Injen Intake
SHIFT_COUPE
Car: 2010 Altima Coupe 3.5 SR 6MT
Re: Reset Airbag light? (SHIFT_COUPE)
Postby 08altima35 » Fri Nov 21, 2008 6:53 pm
just tried this tonight and in another section of nico it said wait 3 seconds between turning off and back to the on position. it didn't work until i tried Robs method.
Thanks dude.
Artisan Performance Turbo Charger.
Artisan Performance Turbo Back Exhaust.
FoxMarketing.Net BodyKit
08altima35
Car: 08 Altima Coupe 3.5SE 6Speed Manny Artisan Turbo Dark Slate
Postby Tommy:] » Thu Apr 23, 2009 6:09 pm
EDIT: Finally got it, took a few tries
Modified by Tommy:] at 11:30 PM 4/23/2009
Tommy:]
Car: Altima Coupe 2.5s MT
Postby Taz1 » Thu May 28, 2009 6:14 pm
So which is it, 3 seconds or 7? Can this get clearified I'm having the same problem.
Tanabe exhaust
Fujita Short ram intake
Custom Emblems
Taz1
Car: 09' Altima Coupe
Postby Taz1 » Mon Jun 01, 2009 4:33 pm
Nevermind I got it. Thanks for the help.
Taz1
Postby SHIFT_COUPE » Mon Jun 01, 2009 4:51 pm
Welcome Taz! Glad the fix worked for you!
SHIFT_COUPE
Air Bag Light
Postby MIATimmy3.5 » Fri Aug 28, 2009 1:13 pm
I was putting a Hi LO Converter by the time I was done I had that air bag light I've been worried for two days I was going to Nissan tommorow and pay $100 to check the system. I tried this and it worked on the first try. YOU GUYS ARE LIFESAVERS THANKS!!!!!!!!
MIATimmy3.5
Car: 2008 Nissan Altima Coupe 3.5
Re: Air Bag Light (MIATimmy3.5)
Postby headhunt3r » Fri Aug 28, 2009 1:29 pm
Props for searching for the answer!
headhunt3r
Car: Altima Coupe 2.5S w/ CVT
Postby BrianMD » Thu May 27, 2010 3:08 pm
Yeay!!!!
It worked first time for me.
Thought I had to go to the dealer until I read this.
So so happy!
BrianMD
Return to Altima Coupe
