loystock »
https://forums.nicoclub.com/loystock-u10145.html
Wed Feb 24, 2010 4:24 pm
Here's a procedure from the FAQ 'sticky' on top of this forum, courtesy off 'jeffadamshti.' I don't think the Bose headunit removal will affect the key fob programming.
I de-programed it, here is how to fix it if anyone ever needs to re-program a nissan key fob. Car is still stalling, could it be ECU, radio face went dead, still plays but its so hot..? Might be fule filter.
I recently had to replace my remote, but I was unable to find anywhere on the Web the instructions for registering the remote unit with the car's computer. I eventually obtained the following instructions from an Infiniti Dealer and I have posted them below.
1.Get in & lock the doors2.Insert the key into the ignition 6 times within 15 seconds3.Hazard lights should flash4.Put key back into the ignition & turn to Accessory5.Press the master door lock (on drivers door arm rest) unlock/lock6.Hit the lock button on the remote7.Hazards should flash8.Pull key out and open the drivers door and then close it9.It should be set
These instructions worked perfectly for me. If you have more than one remote, I believe that you repeat step 6 for each remote before performing step 8. However, I have not tried registering more than one remote.
