maxiiiboy »
https://forums.nicoclub.com/maxiiiboy-u232385.html
Mon Mar 31, 2014 11:03 am
Yes, when the IACV goes bad (usually, its winding becomes "short") it is quite likely that it will damage the ECU; in particular, the shorted winding will overload and "fry" the driver transistors in the ECU. When that happens, it's essential that you repair the IACV before replacing the ECU, or the problem will repeat itself. Re. the ECU, if whomever you sent your ECU to will repair it properly (and that's a big IF), then you should not require any additional adjustments.
There is a ton of information on this subject on maxima.org.
