ARKQX33V6 »
https://forums.nicoclub.com/arkqx33v6-u165721.html
Sun Jun 12, 2011 6:08 am
Every so often if you try something different that what the book states things can go better. As far as changing coolant by removing the lower rad hose it is the norm. The petcock jams up very early in life and playing with it to do the change over is just too expensive and time consuming.
It took time, but many sites about maintenance now write up the job the way I have been doing it for 12 years. And with the lower rad hose removed it just happens to be at the lower end of the internal cooling chamber. So removing that lower rad hose has 2 affects. It gets you to dump the rad, easier if rad cap is off and it dumps coolant form the motor, easier if the top breather is open.
Remember that filling will have air trapped internally that MUST be removed and allowed to escape by the top breather orifice.
It is best to use long life coolant and distilled water, then this job can be done every 5 years.
When empty examine the internal rad look for plaque build up on the small channels. If you only use distilled water there will be no build up.
NEVER TOP UP FROM A GARDEN HOSE, NO TAP WATER. If your coolant system is kept clean internally and externally you should never have to top up as long as you have been servicing it regularly.
Note the external fins especially at the top and bottom joints.
