Replacing thermostate on 2004?
A forum for the Nissan Quest... minivan lovers unite!
michelangelo
Check Engine light on. Code reader says thermostat.
1. Where is it located (left side...follow the hose)? I dont have the van handy, wife just called me and I'm doing research before I get home and buy a new thermostat to instal.
2. Is there anything of notice I should be aware of when replacing it? Is it easy to get to and unbolt to replace?
ricebike
2002 Quest
2005 Altima
http://www.nicoclub.com/FSM/quest/2004_Quest/ma.pdf
MA-14 to locate the drain plug; yes there is one!
http://www.nicoclub.com/FSM/quest/2004_Quest/co.pdf
scroll to CO-19
http://www.nicoclub.com/FSM/quest/2004_Quest/pg.pdf
page PG-27 to move it out of the way to access the part below
ps: that's an expensive part because
engine coolant inlet and thermostat assembly
instead of a traditional t-stat
seems to be a tight fit; hope you have skinny fingers
good luck :whistle:
michelangelo
thanks.
But it ended up being a thermostat sensor. A $70 sensor. $150 later from a local mechanic and it's fixed. Thanks for the help though.
ricebike
2002 Quest
2005 Altima
:welcome: thanks for the update; appreciated it
but in hindsight, if you posted the trouble code, I would have saved you a boatload of $$$$$$$$$$$$$$$ :picard:
autozone's duralast coolant temp sensor with Lifetime Warranty
# SU4072
$21.99 plus tax
& it's an easy part to remove / replace (I woulda done it for $20 labor)
:whistle:
http://www.nicoclub.com/FSM/quest/2004_Quest/ec.pdf
EC-187 to EC-200
michelangelo
yeah that sucks. to spend that much but after it not working and nearly leaving my wife stranded when I work an hour away it was a little expedient that we get it fixed asap. Next time I'll know better and post up.
ricebike
2002 Quest
2005 Altima
:werd:
just curious; was this at a stealer-ship or just an independent shop? because either way they ripped her off if it was the latter :gotme
usually can have the trouble code scanned at autozone or advance auto parts or o'reilys etc for free as well.
michelangelo
We did get the code at autozone first. But we didn't have time or know how to get it done ourselves. Code didn't say if it was the thermostat or thermostat sensor.
It was an independent shop. And yes I know...they're all rip offs, esp the stealership! $90 for a second key!!!!??
I do or try to do most of my own work. My dad's a mechanic and I don't like to pay someone money for something I could otherwise do myself. Plus it's middle of winter and freezing in my driveway didn't seem like fun.
Return to “Quest Forum”
