Replacing the shifter boot-350z DIY
Nissan 350z / Nissan 370z technical discussion forum: Maintenance, performance, installations, modifications, how-to's and troubleshooting.
dasoupdude
Car: 2005 Nissan 350Z
I decided to give a redline goods product out for a spin,
as seen here:zer...66103
and a thread by the hitman himself:zerothread/90783
As easy as it sounds, this took a bit of time. Parts of the process included the weird feeling that you were just about to crack the mounting ring.
I give this a 2/10 Easy rating.
Tools needed: Philips Head
1. Pop center console out with your hand. Unplug the ribbon wire of a/c controls.
2. Remove the shiftknob (zerothread/408283-diy-swapping-the-oem- ... -shiftknob)
3. Introducing my new shift boot, made from faux alcantara. Has orange and gray stitching to match the theme of the Z.
4. Remove all screws on the bottom of the mounting ring.
5. Disconnect the shift ring from the mounting ring. (one of the more annoying parts.The clips are tiny as hell)
6. Pry the boot off the ring.
7. Since the new boot is custom fit it should match up perfectly to the ring, to skip the direction confusion of what goes where just find the 4 holes and match it up to the 4 studs on the ring. The opposite side should have only 2.
A) For the holes which line up with the clips, you need to poke a pencil or pen through them to help give the clip more clearance.
8. If you turn the old boot inside out, you'll notice the collar is still inside. I did not reuse it, but you can if you really want to. Putting it back on is a pain in the a**.
9. Put everything back together and you are set.** careful when mounting the ring and boot ring back, if you find yourself having trouble with matching up with the screws, it could possibly be that you put the ring upside down. (I did, it took a while to figure out )
RemixZ
Car: 2003 350z Touring & 1990 300zx NA, Past Sold 1991 NX2000 & 1999 Frontier King Cab
I just ordered a two-tone black perforated with white carbon fiber with red stitching. Maybe you can get $10 for a refferal?
dasoupdude
hahaha win, take pics of it when you're done.
350ztwinturboKING
Car: 350z TWIN TURBO DUH LOL
I have been banned for attemting to have sex with sheep
RemixZ
Here's mine.
chisox1988
Car: 2003 Nissan 350z
could you repost the pictures? they say they're unavailable right now and im trying to replace mine as well.
Thanks!
dasoupdude
Bad news chief, i tried finding them and I have no clue where they went
It's not even on my hard drive, I can guide you, what do you need help on
Return to “350z / 370z Technical”
