I did but all the threads I saw was for non BOSE systems. One post did mention he have a Bose system and he mentioned that all he hear from his 6 x 9 on the front doors are base and everything is coming from the center speakers and the 2 tweeters, now that got me really confuse and plus I already ordered my 6 x 9s and is scheduled for delivery today.Rogue One wrote:Dude you should search the site first. This has been covered extensively in several threads, complete with detail photos.
Then you missed this... post6479750.html?hilit=speakers#p6479750Nick2010 wrote:I did but all the threads I saw was for non BOSE systems. One post did mention he have a Bose system and he mentioned that all he hear from his 6 x 9 on the front doors are base and everything is coming from the center speakers and the 2 tweeters, now that got me really confuse and plus I already ordered my 6 x 9s and is scheduled for delivery today.Rogue One wrote:Dude you should search the site first. This has been covered extensively in several threads, complete with detail photos.
My reply in that quote is important info need when trying to swap out BOSE equipment. Then there's the BOSE related info in this one... installing-aftermarket-speakers-t449536 ... t=speakersRogue One wrote:I doubt it. The Bose HU sends a balanced signal to the rear amp, and there's an additional amp for the sub. Check for an amp under your rear seats.Qashqai wrote:Hi Yev. Sorry for the confusion. I have a Nissan Rogue and my nick name is Qashqai (I know it is stupid, but in Qashqai forums, my nick is Rogue )
In 2011, the Rogue SL has BOSE and its woofer inside the spare tire. If you are right, it means I have the harness for the BOSE woofer? wow. So in theory, if I change the head unit and find a woofer, I will have a BOSE system?
And just for giggles here's one other...Leo2005 wrote:Information was taken from http://www.metraonline.com
Without Bose:
Speaker Specifications
Location Size Depth
Front Speaker 6X9 3
Front Tweeter 1 1
Rear Speaker 6.5 3
With Bose:
Location Size Depth
Front Speaker 6X9 3
Front Tweeter 1 1
Rear Speaker 6.5 3
Center Speaker 3 2
Subwoofer 6.5 2
Rogue One wrote:From the Bose website:
Q. Can I get a list of technical specifications?
A. No, because our custom-engineered, complete system solutions largely supersede conventional audio measurements. Even some basic building blocks have been redefined—including amplifiers, speakers and equalizers. But most importantly, our integrated systems deliver results significantly different from those of conventional systems with individual, unmatched components. With a Bose automotive sound system, the location and design of the speakers can be much more important factors in determining output than a wattage power rating. The bottom line? The best way to test a Bose system's sound quality is to use your ears, not a list of specifications.
Hmm, Smoke and mirrors comes to mind.
sorry to hear that, was it stock? or something you've replaced?Rogue Three wrote:My front right speaker actually blew out in my 2012 SL. Luckily, it's under warrantee.
Still using the original Bose amp & the speakers fits properly with no adapters needed. Make sure your windows are down when you install just to be on the safe side. Also you might need to drill a screw hole on the door depending on the speaker you are getting.Nick2010 wrote:thanks but I've read all those threads, I've been browsing about this subject for the past 2 days.
@NikNok- thanks for the info, you answered most of my question on your first sentence. I have worked on the Rogue's front door panel before (installed my side mirror LED) and I think I can replace the 6x9s easily, any "gotcha" I need to watch out for on the rear door panel? how's the fit on the JBL GTO628? Also, did you just replaced the speaker and did not install any additional amp?
