How to Replace Piston Rings
General discussion forum about all things Datsun! NOTE: If your thread is specific to a certain model, please make sure you post it in the proper forum.
phlebmaster
Car: 1973 240z L26 4spd rip roar and ready to go!
odpl_moparvwfreak
nice! at least now the motor is good to go since you did the top end work.
phlebmaster
Yep! :cool:
You know what?...now I need to post what I did to the head and a how to for that.
mklotz70
Did you get everything with stock dimensions?  ...as opposed to .030 over
Did you have to put the rings in the cyl to check the end gap....or are they good to go because they're stock dimensions?
Nice work!  Did you take a compression test afterwards?
Approx. cost on the kit?
phlebmaster
Good point Mike...I edited my post. Thanks :cool:
phlebmaster
I made a video after I rebuilt the head and it smoked View My Video
...so here is after the piston rings and bearings.
See attached......................:dude:
http://img532.imageshack.us/my.php?imag ... 097zl0.flv
IMH
Yeah, I stopped doing valve jobs without doing the bottom end too a long time ago.  A nice tight sealing head will just cause added stress on weak rings and you'll end up doing the bottom end sooner or later so you might as well do it all at once.  I notice that your radiator must not be from a 620 as the top hose nipple is on the wrong side.
Return to “Datsun Chat”
