Have you done any or much engine work before? Pulling the plenum is not for the inexperienced.If you are replacing all 6 injectors, pulling the plenum is the right way to go, if you have additional things youwant to do such as valve cover gaskets, maybe the coolant bypass etc.If it were me, and I had limited experience and no one with experience to help, I'd do the Dremel grind method even if it were all 6 as it is quite a lot of work to pull the plenum and get it all back together properly if you are not mechanically inclined and have previous engine mechanical experience.REad the link the previous person posted on p;enum removal, and also this one on Dremel metod
http://www.twinturbo.info/
Click on Z32 and then on Injector Dremel
