NutriaforBreakfast »
https://forums.nicoclub.com/nutriaforbreakfast-u77129.html
Fri Feb 15, 2008 10:49 am
I would get new CV joints. You can rebuild but it lookspretty tricky and time consuming. I had some friends whotried rebuilding them and they fell out at Jack in the Boxon a 96 Maxima
You are going to want to replace the transmission seals tooif the CV joints go in like the 1995 ir 1996 maxima!!
Check your brakes while your at it and get that done if needed.
If your power steering needs adjusting it is a good time to do thattoo, as well as changing hoses, degreasing etc.
