Soravia »
https://forums.nicoclub.com/soravia-u34591.html
Sun Oct 21, 2007 1:29 pm
Every S-13 owner knows how uncomfortable those worn out 15 years seats can be. Instead of buying generic seats with 'universal' seat-rails from eBay, I decided to get something that feels good, looks nice and easy to put in.
Old seats in the S-13 I crashed. They got painted black later on the red body. The same dash, center console, steering wheel and carpet also are now in the Red (for now) body.
I tried many different seats from Integra, 300ZX, Civic Si, Mitsubishi Lan-EVO and settled on Celica GT-S 7th Gen seats. Those seats have low height and narrow enough to fit in the S-13 chassis. Plus, unlike the Honda Integra seats, they don't cost an arm and a leg . Especially if you get it from someone who's throwing them out from a wrecked car or stripped race body.
There were choices of leather or Ultrasuede. I didn't want my rear being burnt by the car seat in a hot day so I picked Ultrasuede. eGay aftermarket seats have a choice of mesh nylon as well.
The seat-rail heels from Celica are very close to S-13 original mounting holes and only the outer-side heels require modification. You will need a 4" Grinder with cutting wheel and a welder. Painting is optional but recommended to keep it from being rusted.
When you get the Celica seats begin work on the passenger side. In case of massive failure you can still drive the car w/o a passenger seat.The inner heels don't need to be changed but cut or drill the bolt mounting hole in them a little higher (about 1cm) to keep the seat as low as possible.
All you have to do is bend the front heel to fit in the front mounting hole on the floor. You can achieve that easily by putting a rachet socket extension or thick screwdriver into the hole of the heel and push it against the rails to bend it. You don't have to put in a lot of force so don't try to break it.
Now the real work starts on the outer side. First start on the front heel.Unbolt the outer rail from the original 240sx seat and cut the front heel along with the rail it is attached to. Cut it exactly at the end of the heel-to-rail attachment. Also cut the front part of the heel (but not the rail) from the Celica seat. You will want to leave the base of the heel attached to the rail because it gives about 2mm of required height.Clean the rail and brush off the paint from the base of the Celica heel and the top of the rail cut from the 240sx seat. You can use the flat surface of the cutting wheel to acheive that quickly.Align the front ends of both heels to each other and weld them together. If you choose to tap-weld them while sitting in the car for exact fitment, I recommend using a thick wet blanket over the carpet to prevent it from being burnt.
You can see the blanket over the seats while it was being welded. I should have had it covered from the bottom. A small piece of weld bounced off the floor and burned a small hole on the inner side.
The outer rear seat heel has to be done at last for best fitment. The rear heel of Celica seat is extended to outer-side where the 240sx seat is extended to the rear.First, cut off the heel from the seat rail of the original 240sx seat and mount it on the car's floor. Remove paint from the heel of the Celica seat by brushing with the side of the cutting wheel. You want to cover the carpet with wet blanket to prevent burns. Then mount the seat in all the other heels. Adjust the orignal heel to support the Celica seat heel and give a little tap welding.Wait for a while for the welding to cool down. Don't use water as it can weaken the welding joint. Take out the seat from the car and cover the seat with wet blanket to prevent burns. Weld the heels together from all sides to give it good strength. You don't want them breaking off during a side impact.You can also try to mount the heel by completely cutting off the Celica heel and cutting off the 240sx heel with part of the rail like on the front heel. But you will still need additional 1.5cm of height.
When all the welding are done you can use a grinding wheel to smooth out the weldings and start panting. I recommend using clear coat on the paint for better holding. You might want to sand the metal plate on the bottom of the seat and paint over as it will be a little rusty on a used Celica seat. Use masking tape to prevent painting over the seat farbics or leather.
The mounting bolt for Celica seatbelt receptor is exactly the same size as the original 240sx bolt. So just clean up the old receptor and replace the Celica seatbelt receptor.
The S-13 two piece belt doesn't fit perfect with the new seat. The upper belt reaches higher than it should and needs adjustment.
Quick and dirty way to solve this is to route it under the lap belt. Or you can fabricate a loop hole for the belt to pass under and stay a little more to the front than it would otherwise.
The seat heels mounted in perfect.Inner Rear Heel
Inner Front Heel
Outer Front Heel
Outer Rear Heel
The new seats for S-13
Height Adjust for Driver-side only.
All it cost me was $200 for the seat, including work on welding and stuff. Grinder and paint cans were mine though.
Modified by Soravia at 7:59 PM 10/21/2007
Modified by Soravia at 7:22 PM 11/7/2007
Modified by Soravia at 7:27 PM 11/7/2007
Modified by Soravia at 7:28 PM 11/7/2007
