Kind of a bummer that it failed at under 100K, but I guess any part is fair game at 21+ years old. I'm guessing that long cycles of sitting between starts, pretty much for the car's entire life, caused it's early demise. I should invest in a good trickle charger.
You can tell this car was designed by people with small hands. On the old Q, I had my dad available to help out with getting that damn retaining nut on the through bolt. Since he's not available now, I ended up dropping the A/C compressor to get it back in. Otherwise I followed the instructions in the FSM. I tried the superglue trick on the nut, but kept knocking it off.
So if anyone reads this in the future, here's my advice:
- The FSM says "Remove harness heat shroud by pulling alternator to radiator side" (forward). Forget about that... it won't disengage without a screwdriver rammed inbetween the plastic and the metal studs that bolt on to the back of the alternator. Just clip the cable ties, get the shroud off when the alternator is out of the car, and then cable tie it back in place with new ties.
- Removing that upper alternator upper bracket (that also holds the dipstick tube in place) is a big help.
- Go ahead and drop the a/c compressor. Three out of four of the bolts are easy to get to. The back one isn't bad if you have a ratchet with a long handle to use. I just used my torque wrench...
- Fully anticipate hating your car for the duration of this job, and maybe for a few days after you're done. My neighbors probably got tired of hearing me yell "who the f--k thought up this design!!!!!"
Heath
