replace the factory's amp.
Discussion forum for body kits, repair, modifications, interior styling, Audio / Video and internal/external lighting.
infiniti2007
Car: 2007 infiniti g35x
I would like to replace the 2007 infiniti g35x 's factory amp to after market 's amps. Does anybody do it yet? Please let me know. Also please tell me where I can locate the factory amps and the color wires. Thanks.
Tampa G35 Sedan 6MT
Car: 2006 Infiniti G35 Sedan 6MT Black w/ Premium & Areo Pkg
1989 Jeep Cherokee 4X4 Lifted and Old School!
wow are you doing a major audio upgrade on your G?
Im sure someone has done it and will be around shortly!
DJ
zozoka1212
Car: 08 Infiniti G35x
I sent you the service manual via email. What you loking for is close to the bottom of the page. I believe.
zozo
joe603
Car: 2014 Durango R/T
Just be careful...the Bose speakers use a 2ohm impedance (normal speakers are 4). This will cause the amp to push more power...you will not need much more than 25 watts RMS per channel. If you replace the speakers, thats a different story!
smockers83
Car: 2006 G35 Coupe
+1 for what joe said. Most new amps today are stable down to 2 ohms, so that's something you'll also want to make sure of. If you can't find a 2 ohm power rating, its roughly twice the power rating of a 4 ohm-rated amp. Theoretically, cutting the resistance (ohms) in half should double the power output, but there are inefficiencies to take into considerations. If you're replacing the amp, you might as well spend the extra cash for even better sounding speakers.
smockers83
Car: 2006 G35 Coupe
And just noticed you're from the D. Welcome aboard.
infiniti2007
Hi Zozo, the service manual you have sent me , not working. documents is not found, every time I clicked on the topic I want to read. Could you sent it again please. Thanks again.
infiniti2007
yes , I have to replaced the speakers if I want to replaced the after market amps. Thanks for bring that up.
smockers83
Car: 2006 G35 Coupe
I don't know what zozo sent you, sometimes he's a little out of it haha. But here's a link to the FSMs as well. You kind of have to guess at which one you want--the two letters stand for different systems, like av would be audio video. Best way to view them is to right click, and Save Link As...sometimes they have a little trouble downloading them when you try to open them from the site.
Good to see someone else from MI, I think we're the only 2 in the G forum.
infiniti2007
Thanks Smockers83, it nice to hear you pro.
smockers83
Car: 2006 G35 Coupe
I just realized I forgot to post the link. Here it is. My bad.
http://www.nicoclub.com/FSM/G35/
Return to “G35 and G37 Interior, Exterior and Audio”
