Gort400 wrote: ↑Fri Dec 10, 2021 4:29 pm
I just checked my battery voltage with the engine not running. It was 12.8V. I then started her up and got 14v. Ran her for about 15 min and it was 13.8v. Shut her off and battery went to 12.9v. I think the alternator is ok, but not positive. I will monitor.
Those voltages don't sound bad.
The alternator voltage regulator is temperature-compensated - which means that it adjusts the alternator output voltage depending on ambient temperature.
In very cold weather, you might see battery voltages in the very high 14's, especially right after a cold start.
In very warm weather, it could be down in the low 13's.
Your 13.8 volts is a very typical number.
