Matej »
https://forums.nicoclub.com/matej-u32848.html
Sun Aug 16, 2009 12:38 am
Currently I am in the process of removing and/or plugging whatever I can from the vicinity of the intake manifold. Since my car does not have a heater core installed, I want to remove all the extra coolant hoses as well. However, there a few I am not sure about.
Here I marked the ones I do not know if I can plug. My marks are the yellow ones, please ignore any others. Sorry, the pictures are not mine.
#1Normally this hose would go to the heater core, but since I do not have the heater core, I have been running it looped into the hose labeled #4. Is it alright to just plug it off where it comes out of the block, or would it be necessary to loop into something else if I remove hose #4?
#2This hose runs from where the upper radiator hose enters the top of the intake manifold straight to the back of the water neck. What does it do? It seems that this hose is either very pointless, or very important. Can I remove it and plug both ends, or is it necessary to keep?
#3Alright to plug, or should something be looped into it?
#4Please see #1.
Thank you for any information.
