Removing speed limiter on 93 KA24DET
Mustangs_Suck
babowc wrote:ooohokie i guess ill be changing to the auto.. never knew 240sxs got this kind of.. not-so-great gas mileage
clean out your motor with sea-foam if you can find it. also get new spark plugs, spark plug wires, and distributor cap/rotor - those will help greatly if they haven't been changed in awhile, or at all.
As for the sea-foam. Buy one can and do as follows:Put 1/3 bottle of sea foam in the crankcase oil1/3 in the gas tankand 1/3 in the vacuum (you can use the metal tube that sticks out from the left side of the ECCS)
When you put it in the oil, let it run at idle for around 15 min. and then change your oil.
You will feel a big noticeable difference in how well the car runs, and more MPG I assume as well, since it'll clean out your gas lines and injectors when it squirts through them from mixing it with your gas.
phuphyter
Car: 2002 Infinity G20
Cool. Now all I got to do is swap the ecus from my '94 altima and '91 240! My parents will never know... muahaha
Florida240sx
I only ran my car at idle for 10minutes....178k miles...that's just me though
locolou
Honestly the easiest way to disable the speed governer/rev limiter is to cut the correct wires from the ECU. At first I wired in 2 switches in case something stopped working, but I've had no problems since doing it so I removed the switches. All you do is snip ECU wires 32 (yellow/green) and 33 (yellow/red) and your all set. If you have cruise control, you will probably lose that, since I have a base model, I wouldn't know.
side waz
Car: 1990 R32 Nissan Skyline GTS-T Type M, RB20det. Previous car 1991 240sx SE fastback, KA-T.
locolou wrote:Honestly the easiest way to disable the speed governer/rev limiter is to cut the correct wires from the ECU. At first I wired in 2 switches in case something stopped working, but I've had no problems since doing it so I removed the switches. All you do is snip ECU wires 32 (yellow/green) and 33 (yellow/red) and your all set. If you have cruise control, you will probably lose that, since I have a base model, I wouldn't know.
So your saying you cut the 5th Gear Switch wire (ecu #33) and you have NO rev limiter in 4th and 5th gear's?
According to the pin out diagram, 4th gear is #42 and 5th is #33. Now would'nt you have to cut BOTH wires in order to fully remove the rev limiter from those gears?
streetracer
Car: 240sx hatch
I know on my 1993 240sx se hatch i have cut all of those wires.(32,33,42)I still hit the rev limiter at 5000 rpm's and it sucks. i am going to disconect the two sensors from the trans and see what happens since i have nothing to loose except a rev limiter at this time.I have notice that on the 93 hatch the # 42 is white and #33 is black i am not sure that it is the same with every one else or i might have did some thing wrong on the wires but when i read what some one else puts in on the forum i do that and the car don't wan't to start untile i hook up the wires back up. And one thing i notice is that 32 is right above 33 and 42 sits right next to 33 on the left side of 33.
streetracer
Car: 240sx hatch
I have un hooked all the sensors in my 93 hatch and it worked no speed limiter any more. Had to jack up car and climb under the front the the car just to get to the 4 sensor that are on the passenager side of the car.The only reason is that i had to use two hands to unhook two of the seansors have little clips on the side of the sensor that have to lift up just to get the little sensor to move. They are not that easy to pull apart so i recomend using two hands instead of one hand.
Biggamehit
Car: R33 Skyline
DR30 Skyline
Sil80
180sx
just take 10 min and run a simple on and off switch. mine works fine no redlining.
pics below buddiesmy wires run through the hole in the trans tunnel through the shift boot and then under the dash and to my switch
Biggamehit
Car: R33 Skyline
DR30 Skyline
Sil80
180sx
delete sorry
Chezedik
Car: 1991 Nissan 240sx
How does this ECU swap affect readings on the speedo?
Guardians91240SX
Car: 1995 Nissan 240SX auto 4 lug
1991 Nissan 240SX SE 5-Spd Sadly it was sold to pay bills
1979 Plymouth Volare 408" Bigblock auto
But what about the fuel pump cut out ? how is that eliminated ?
ale89se
Car: s13 silvia
so when you cut the wire i understand that all the guages work fine, but will i get the check engine light on all the time after that?
rsmithdrift
Car: 1993 240sx fastback se.
bump.
I want to know about this check engine light also. I don't want it on all the time........though I don't see why cutting the speedo wire from the ecu would make it come on, but the 4th and 5th gear thing I would think would freak it out or make the rpm gauge not work. I want my rpm gauge to work in 4th and 5th and not have my engine light on.
Also I have cruise control and use it alot (only way I can keep it under 80 on the highway lol) and I would like it to still work.
Florida240sx
I cut #32 and it removed it for me.Although for some reason I think I hit it in 5th but that was close to 140mph.(I was turboed) Could of either been road(rained 4hrs before and tires may of been slipping or could of been MAFS maxed out. But I sniped the yellow green and my cruise control still works Nice to be cruising along and when you go up a hill you hear your turbo spol automatically.
rsmithdrift
Ok, cool thanks, good to know.
What about that engine light though. Sorry for being a pest about it, but I don't want it on.
edit: Ok, forget the engine light part. I just did it and the engine light does not come one, but there are two yellow/green wires and I cut one and I have no speed gov, but my cruise don't work. Did I cut the wrong one?? I'm assuming this is the same wire, maybe one affects cruise and the other don't??
NVM. I was right, I cut the wrong yellow/green wire. I crimped it back together and cut the other one and viola!! Cruise control at 130mph lol. J/k, I wouldn't dare use it above 100.
Modified by rsmithdrift at 3:38 PM 2/4/2006
Florida240sx
What you mean?My cruise only lets me go to 95mph. have you been able to set it over that?
Jookmasta
i know its 92mph from my digital speedo gauge that the cruise control maxes out........
rsmithdrift
I said I was joking geeze. I've never set it above 80. I was just saying with that comment that I wouldn't want my cruise on at over 100.
Florida240sx
Got to unplug the sensors.MY car cuts off at 5600ish rpms in 5th. Made my car stall out......not very fun at all at those speeds....was a backroad in between counties before I get flamed.
ka24boos13t
Car: 91 300zx tt
S13FX wrote:Just a quick note it's the same wire for the SOHC too
Are you sure? I snipped the yellow with green striped wire 8th from the right and it cuts out in 3rd under hard exceleration. Is this pin 32? (I dont have the manual so I have no idea) Everyone in this post has said that its the yellow with green stripe and in another post someone said that its the 8th over from the right (I figured that it was the right wire since they both coincided.)
Modified by ka24boos13t at 4:15 AM 3/27/2006
PencilShavings
Car: '91 240 hatch
ka24boos13t,dont know if you saw this yet, but check it out...(i think its only about 20min from you)
zerothread?id=145840
zerothread?id=164906
nwdrfter
Car: 240sx
dang i'm hella confused here, but i guess i'm gonna go for the yellow/green wire on my 89 249 swapped out to a 93 ka24de. hope it works. still unsure as to which one(s) of the four on the transmission i gotta take apart. any help?
side waz
Hey man what's up.
Yep, go ahead and snip that wire and the speed limiter is gone. Your speedo will still work perfectly as well.
Now as far as which transmission sensor's to un-clip, well you know how there's two round shapped ones and there's two more rectangular shaped ones? Well I un-cliped the rectangle shapped ones and that removed the rev limiter and again, the both the tach and speedo gauges worked just fine.
Hope that helps.
Kittychubbs
Car: 180sx Ae86 Aw11 and a VIP ^o^
hey bro .so u did urs already and worked! good jobmay u give me a hand and correct me if am wrong.
so i go cut yellowgreen #32 from ecu where is the ecu located kick panel?-------------------------------------------------------------------------------------and then go under the car n disconnect the 2 "squared plugs" and thats that!??!?!
or do i do the to middle ones 2 n 3 ?? one round one squared?
thank u alot man!
side waz
Kittychubbs wrote:hey bro .so u did urs already and worked! good jobmay u give me a hand and correct me if am wrong.
thank u alot man!
Yep thats all there is to it man. Snip the wire, ECU is in the passenger side panel, unclip the squared plugs, tape them up properly and bingo..... NO SPEED LIMITER or REV LIMITER!
Kittychubbs
hey man so i unpluged the squared (ish) ones the clip its on the side.and now im gunna go cut the yellow with green stripe cable from the ecu here goes nothing hope it works!!!
thanx Bruce!
Modified by Kittychubbs at 8:36 PM 6/30/2006
Kittychubbs
okay i did everything 1st thing yes all speed/rpm/gas gauges work!!
BUT
I notice the engine gets a bit loudder thatn before at around 5500 rpm when racing it and yes it went over 7 k rpm
but is that safe with stock internals. i mean i dont wunna blow the engine up lol
and it uses more gas than usual so i say mpg did go down in my case a bit
i havent yet taken it to see if the governor its gone well i hope so, i hate it.hahaha
the rev in redline well kinda got me a bit nervious it seems the engine forces itself a bit more when it goes in the redline is that normal??
correct me if Im wrong I guess u need the NO REV limit so u can take full advantage of the NO Governor trick. cuz if it had rev limit it would bounce off n wouldnt let u go faster when u got to 55k rpm in 5th gear.right? maybe? lol
Modified by Kittychubbs at 9:22 PM 6/30/2006
Kittychubbs
BUT
the rev in redline well kinda got me a bit nervious it seems the engine forces itself a bit more when it goes in the redline is that normal?? what its a new rev u guys recommend 7k even?7500K?
or just the normal 6ish k before redline ? ( it seems the no rev limit its more of a backup like 500 more over the line to be safe.
240sxs1377
Car: 1993 240SX
so what speed would you be at 6800 rpms in 5th gear?
Kittychubbs
i wonder hummmwell guys it works!! no top limiter since yesterday i tried it, n no more Governor woot woot!!!
