GRNMACHINE »
https://forums.nicoclub.com/grnmachine-u133452.html
Fri May 07, 2010 6:49 am
Maybe took an hour at the most. Out of all the rusted/snapped off bolts these held up fine. I did not need a breaker bar at all. Just a decent socket set. The bolts are all the same size and very easy to get to on the Path. You can always spray the bolts down with PB Blaster for a few days before you take them off (or a few hours). Path is mostly garage kept and I usually spray the undercarriage a few times a year with WD40 etc, that may have helped with the bolts. One word of basic caution, lots of rust particles etc will fall once the bars are moved etc, make sure you are wearing eye protection if you are working underneath them.
