Removing interior trim?
All things Altima Coupe.
bigmikewarren
Car: 2009 Nissan Altima Coupe (Azure Blue)
OK. Has anyone tried removing the interior trim in your A/C?
Specifically, the door pull trim,
the steering wheel trim,
And the shift gate,
I am thinking about painting them or something.
Anyone tried this or know how to remove them?
Mike
bigmikewarren
bigmikewarren wrote:OK. Has anyone tried removing the interior trim in your A/C?
Found this: http://forums.altimas.org/zerothread/340907 for the door pull trim. So does anyone know if the steering wheel trim comes off just the same?
And let's not forget the shift gate?
Thanks.
Mike
srwong
Car: 2009 Altima Coupe 3.5 SE CVT
bigmikewarren wrote:And let's not forget the shift gate?
Pull really hard down on the chrome trim piece n te bottom and then pull out the retaining pin and the knob will pull upwards....
also make sure to unplug the cords when u remove this
PHENOMenalVinyl
Car: 08 altima coupe 2.5 mt
bigmikewarren wrote:Found this: http://forums.altimas.org/zerothread/340907 for the door pull trim. So does anyone know if the steering wheel trim comes off just the same?
Thanks.
Mike
seriously have you NOT looked on the forum latly me and like 4 others have posted this lol ive had it done since the summer but its legit mad easy
doors pop them off from the nottom corner up w/ a knife to pop it up
steering wheel theres two bolts u need to undo but b4 that unplug the battery or the horn will go off.....there on the right and left one on each side ......u gotta pop off the black covers oveer the bolts n then theres 2 screws on each piece of trim
boystar22
Car: 2008 Nissan Altima Coupe 2.5S
You have to remove the airbag to take off the steering wheel trim. Its bolted onto the sides of the airbag from behind.
coupecrazy1232
Car: 2008 Nissan 350Z Nismo 1430
here is a thread where i did this...at some point in it i believe all pieces are covered on how to remove lol if not email me and i will help u out...
http://forums.altimas.org/zero...ieces
bigmikewarren
Excuuuuuuse me. New here. And I did search, but depending on what keywords used, results vary. I was using the term insert, instead of trim.
bigmikewarren
I truly appreciate the help on this. I will probably tackle the door pieces first. Not sure about the steering wheel trim now that I know they are connected to the airbag. Not looking to screw that piece of safety equipment up.
Again, thanks to all who helped. I am enjoying this forum.
Innovazn
Car: Yellow 1998 Nissan R34 Skyline RB25DET 5 MT - Current
White 2012 Nissan Altima Coupe 3.5SR 6MT - Salvage (T-Boned at left turn)
White 2002 Nissan Pathfinder LE - SOLD (blew the engine)
How does one remove that push door thing infront of the shifter as well as the centre radio /vent moldings?
AlexN09
Car: 2011 Nissan Altima Coupe S 2.5
I just did this to put in a new double din radio. If you slip a screwdriver (blue taped) behind the top right corner of the vents and pull it'll pop out. Work your way down near the bottom and pull pretty dang hard and it will pop out again. Then maintain pressure on that side and pull the opposite side out. Now you'll need to unplug the airbag and hazard cables.
Next open the lower door to the cubby and reach above that door under the stereo and pull down and a little trim piece will come off the radio.
Now you need to shift the car into neutral and remove the shift knob. I'm assuming you can do this because I think you replaced yours already. Now pull up on the trim piece around the shifter to remove it.
Finally you can push up from the very back/inside of the cubby and it should pop up a bit. Then pull forward very carefully and you should be able to remove the cubby. I say carefully because I broke the mechanism that allows the cubby to open slowly.
I think this should work but I should also mention I had the stereo removed as well when I took the cubby out.
Innovazn
^ that was confusing as s***....
iammai
Car: Altima coupe
This thread used to have pictures when Doc made it back in 07-08
http://www.nicoclub.com/archives/altima ... stall.html
AlexN09
Innovazn wrote:^ that was confusing as s***....
Sorry, if it helps any, each paragraph was how to remove each section of the trim. So first the vents, next the piece under the stereo, than the shifter and shift trim, last the cubby.
Here's this: http://www.nicoclub.com/FSM/Altima/2008/int.pdf
Might just be more confusing to you but I use it all the time and I like it.
Irvxing
Car: 2011 Altima Coupe 2.5s M/T
Removing interior trim= rohcket siense :cool:
tug and pull on everything. Screws here bolts there.
First lift up on your shift boot base. It pops out.
Then tug on your chubby, Sorry meant cubby.
It will come out. Its held in place by 2 tabs.
The removal of the Stereo and vents are not necessary IF you have a 6 speed.
1st remove this
then pull on the cubby!
Itll come out.
dangeris
Car: 08 Code Red 3.5
08 BMW 328xi Coupe
90 300ZX 2+0 NA
This post was from B88dragon when he CF wrapped his interior. I ws the first one to do but I can't find the pics or my DIY. The center console was a pain in the A$$ but it was one of those things when you have the console out, you're at the point of no return. I'll dig some more and see what I find and post them up for you to see.
[quote="b88dragon"]So I got some vinyl this pass weekend, and was bored so decided to change up my dash board a little bit as well the two trim pieces on the steering wheel as well. It was my first time working with this stuff, but after enough research and what not I got the basic idea on how to do it.
So enjoy everyone, it was my first time but i think it turned out good.
It was a pain taking this apart, especially this cubby part, it was really annoying.
Don't mind the extra silver part still showing, i fix it afterwards.
