Hi there, I would also like to add this one. You can use it as an additional reference or guide for this kind of stuff. Goodluck!rocnrol wrote:I need to replace the brake light bulb on 2007 altima. How do you remove the light assembly to access the bulbs??
I had enough problems trying to figure it out that I decided to create a step by step video to save everyone else the hassle. Here you go:rocnrol wrote:I need to replace the brake light bulb on 2007 altima. How do you remove the light assembly to access the bulbs??
