MistyEyes »
https://forums.nicoclub.com/mistyeyes-u21838.html
Mon Nov 08, 2004 6:47 pm
I know this is probably too late, but I had similar problems with my fuel door and trunk....The little spring type piece of metal in the fuel door was bent too far in, so I sprung it out so it would pop the door open when I pushed the release.......also the trunk latch on mine has a safety....sort of like a childproof switch in the center just inside the trunk....you flip it and the drivers door latch won't let the trunk open ( they did this so anytime you leave the top down, anyone passing by would not be able to use the lever to access the trunk.....) sometimes I have to flip it again in between times....Possibly I need to oil it.....or change a spring.
