Shocks, springs, sway bars, coliovers, bushings, brakes, wheels, tires - This is the place to discuss G-Series suspension modifications!
by Goodgalz » Sat Apr 28, 2012 10:42 pm
Hi All,
I got some great information from this forum and recently made some mods to my 2011 G37 Vert. I would love feedback and suggestions.
Here are the photos and info:
http://www.goodgalz.com Thanks
2011 G37 Vert-Stillen Gen 3 Intake & Cat Back Exhaust/Eibach Springs & Camber Kit/GT Strut Bar/OEM Black Grille/OEM Spoiler w/Cam & Nav/Tinted Headlights/Ichiba Spacers Next: Sway Bars/UpRev Tune. New Web Pics Soon. www.goodgalz.com
Goodgalz
- Car: 2011 Infiniti G37 Convertible
by audtatious » Sun Apr 29, 2012 8:59 pm
How do you like the intakes?
Looks like you have the tire size for the rear listed wrong as the back should be 245-40 and you have 224-40 listed on the page
Nice car. Spacers in the rear can fill out the wells better.
2008 G37s Coupe | Invidia Gemini CBE + HFC's | Cobb Stage 2+ | GTspec FSTB | BC Coilovers | Hotchkis Sway bars |
Eibach Camber kits | R2C Intakes | TBW engine cover | 20" ForgeStar F14's | 6000k HID + Fogs
2007 G35s Sedan | 20% tint | 6000k HID's | LED's | G37 19" Wheels
audtatious
- Car: 2008 G37s Coupe - 2007 G35s Sedan
by joe603 » Tue May 01, 2012 2:27 pm
Sweet car!
joe603
- Car: 2012 Challenger SRT8
by Goodgalz » Tue May 01, 2012 4:57 pm
Thank you Joe for the compliment. Audtatious has recommend spacers to fill out the wheel wells. Sounds like a great idea. When I can afford it, that will probably be my next mod.
Goodgalz
by audtatious » Wed May 02, 2012 9:36 am
Here's my coupe with 15mm spacers. Looks like you have some room as well.
audtatious
by RED_DET » Wed May 02, 2012 1:15 pm
Spacers are always a nice touch!
RED_DET
- Car: 2004 6 speed G35 Sedan, 2011 G37x, 1992 Nissan Sentra SE-R SR20DET, 1993 300zx TT
by Goodgalz » Wed May 02, 2012 5:23 pm
Very nice car! The spacers really make a difference. Your car looks great. Thanks for sending the photo so I could see just how good it looks with the spacers. I think that will be my next mod.
Goodgalz on Thu May 10, 2012 11:52 pm, edited 1 time in total.
Goodgalz
by Goodgalz » Sat May 05, 2012 10:11 pm
Audtatious, Do you have any problem with the tires rubbing with the spacers? They really look great on your car.
Goodgalz
by audtatious » Sun May 06, 2012 6:27 am
yes and no. I didn't have any rubbing until I put some softer rear springs on and the rubbing is the fender liner being hit. I've cut some of it out but not enough it seems. I also threw the alignment out a bit a few weeks ago when adjusting the ride height so it's primarily the passenger side rear. Once I get camber set properly I should not have any issue.....I had no issue at all with the stiffer springs.
With the 15mm springs I'm running a 30mm offset (factory coupe rear offset is 45mm). People are running 25mm on the coupe with little problem and some are going even more aggressive when using additional negative camber. I want camber "in spec" since I use this as my DD. Now, the vert rear rims are 30mm offset from the factory but the fenders allow for more room to use spacers. I would use a tape measure to see how far the tire is from the lip and determine spacer width by that.
audtatious
by Goodgalz » Sun May 06, 2012 11:23 pm
Thanks for the info on the spacers. I'm going to do some research to fully understand the spacers, offset, camber, etc. so I know what the hell I'm doing.
Goodgalz
Return to G35 and G37 Suspension, Brakes, Wheels and Tires
