Baluga wrote:I've just joined the forum 4 hrs ago...I have a 2005 350Z with less than 7000 miles, Stick shift, since i bought it i can hear noise in the tranie when on neutral. its sounds like the trow out bearing is out of lube which you normally hear when you press on the clutch but the noise i have is the opposite, when i press the cluth pedal the noise is gone then when you release it makes noise tile there something loose parts inside or rubing metal to metal...i took it to the dealership and those F...people dont even test drive it or atleast sit on it and listen , they say thats one of the 6 speed charateristic of the transmission...does anyone has similar problems like mine?..please help...thanks..
My '07 350 Nismo exhibits the same behavior and is now making popping sounds at low/med RPMs when getting into 1st and 2nd gear.
I called Nissan and my VIN does not qualify for the recall...
I called a few dealerships, Courtesy Nissan in North Dallas, and they said the sounds we hear are probably not typical. I would take it to them but I live in LA, not Dallas.
I then called Downtown LA Motors... another Nissan dealership and they also said that the sounds are not normal, esp. with 2200 miles.
Lastly, I called Santa Monica Nissan and they said that the sounds are normal on the newer version of the Z's (07 -08) as the transmissions are newer. I think that I will schedule a test drive with a tech... and have to take a 1/2 day off for this... grr...
Any thoughts from anyone???
