Hi guys - new member here.
My friend has a 1998 Q45...the rear McPherson strut's lower shock-absorber-type bushings are shot. I'm thinking about replacing with polyethylene bushings but I could use the bushing dimensions to pre-plan the job: inside diameter (bolt/stud), outside diameter, length, barrel shape (cylinder/hour glass)...even a part number or 2...
Thanx for any help and advice you can provide.
-Doc-
