While changing rear brake pads, I found the rear brake sensor had jumped out of the socket and was hanging below the axle. Jumping out of the socket was the reason the worn brake pad light came on. Since it wasn't rubbing anywhere, I thought it would be ok. I replaced the 50% worn brake pads with some new Wagner ThermoQuiet and reinstalled the sensor into the copper socket. No luck. I tried resetting the code to no avail.
I found this thread below.
Is the consensus still to remove the sensor and jumper the plug or should I purchase a new sensor?
92-q45-brake-pad-sensor-bypass-problem-t171981.<a class="postlink" href="htmlhttp://forums.nicoclub.com/92-q45-brake-pad-sensor-bypass-problem-t171981.html
