The rear calipers are threaded so using a c-clamp to compress them will damage them. You need this tool or a pair of needle nose pliers to compress the piston.S13 Rear Brake Pad Install zerothread?id=243067SHIFT_240sx wrote:im changing out my rear pads as we speak and i cannot compress the rear piston on the caliper, im using a 6 inch c-clamp and it will not budge, the e-brake is off, any suggestions?
Please, if you know how to use the tools you already have to complete the job without any harm and just as fast as if you had said tool - you're still doing it right.LayNLow240 wrote:cmon, the tool costs like under 5 bux from vatozone. get the proper **** and do it right.
