I performed a little experiment this evening with the line pressure solenoid.
- After looking at the wiring diagram for the TCU, I noticed that there is a resistor between one leg of the line pressure solenoid and ground. This resistor (I assume, not 100% sure) reduces the power draw of the solenoid. I do know that the way the resistor is wired in the circuit holds the solenoid slightly open even when the TCU wants the valve closed, reducing line pressure slightly.
I figured that disconnecting the resistor would increase line pressure since the solenoid can close all the way. Conveniently, the resistor is mounted to the inner fender behind the battery where it's easy to get to. I unplugged it and went for a test drive.
The result?
The 1-2 shift was HARD, like neck-snappingly hard. The 2-3 shift was perfect - fast and no delay.
The TCU caught on to the disconnected resistor, and gave me a "Transmission Malfunction", so I plugged it back in.
Anyway, this points even more to the slow 2-3 shift being the result of a lazy line pressure solenoid and/or sloppy TCU programming that lets the 2-3 shift take way too long. The first could be cured with a new solenoid pack, the second by possibly modifying the value of the solenoid resistor.
After my little experiment, I did some web searching and came up with this link:
http://www.smallcar.com/svx/tsk.htm
(remember the Subaru SVX shares the same basic transmission). This replaces the resistor by a variable resistor that is sensitive to engine manifold pressure.......
