gawdzilla wrote:are the 25 and 26 crank bolt washers the same size?
I'm using the 26 crank bolt/washer with 25 pulley. seems to work fine
I don't know, I used my 25 washer and machined it out.. drilling was no option that metal is hard as fawk. It might just be washer size differences.
Stric make sure your belts line up, when I had my bolt fully pressed on there was still a gap between the back of the pulley and timing belt cover.
The 26 washer might be thicker.
EDIT: they have to be the same thickness because the the two washer fastenel gave me to equal 12mm were the same thickness as my 25 washer.
Maybe my bolt was longer than I asked for? I never mic'ed it.
