I just went through the whole misfire ordeal after taking the car to the track. It developed what felt like a nasty misfire/ignition cut upon corner exit under high load after around lap 5 or 6 (right as I was feeling comfortable) in both sessions. It seemingly went away for the first portion of the second session, but again cropped up around lap 5 or 6. After leaving the track, the misfire continued to pop up about once every few minutes on our 2.5 hour drive back, this time at all loads. It was frustrating.
I got to reading on forums and blogs which eventually led me to a great youtube video out of Australia where a guy troubleshoots the misfire he's experiencing in his '96 BCNR33 Vspec. What he ended up finding was that carbon trails, moisture, and grime along the side of the coilpack body and around the boot caused the spark to travel up away from the cylinder and ground into the metal coilpack frame.
https://www.youtube.com/watch?v=Qirx_G4x5i0
So I bought a tube of silicone grease and some contact cleaner
Pulled the coilpacks out of the car
Disassembled
This is the plug boot on #2 cylinder. Moisture.
This is cylinder #4, water has been sitting here at some point
Plug from #4
Cylinder #5, corroded boot seal
I had just changed all the plugs only a few months beforehand, so they all looked pretty good.
My harness was looking worse for the wear as well, so I purchased a new OE ignition harness which wasn't all that expensive. It will not arrive for another week or so. The center garnish, while looking cool, also causes the harness to bake in the valley.
After cleaning contacts at the MAFs, igniter, CAS, and my old ignition harness, I reassembled the coilpacks and reinstalled everything back into the car.
A cleaned and prepped set of coilpacks. I dabbed a little grease in the boots and at the connectors as well.
Started the car and let it warm up. No hiccups or wavering idle. Took it for a spin and it drove like a champ. Rock solid.
Take a few minutes and check over your coilpacks/spark plug galleys for corrosion and evidence of water contamination. You'll save yourself alot of headaches and probably more than a few $$$ chasing your tail when it could be just as simple as needing to be cleaned.
