RB25DET transmission internal (pics)
DETurbine
Car: S13 RB25
well I am in the process of working on my transmission...I am almost done, just need to replace 3/4th syncro spring clips and bolt it back together. I know I had a hell of a time looking for pictures of one opened up and never did find out, so I want to make it easier for others to find them and/or show people what one of these look like opened up.
Also from my knowledge....these transmission internally are the SAME as a 300zx. I have taken a look at the 300zx transmission manual and compared it to my open transmission on everything so far is the same. I have heard others say that they are as well...the differance with the two transmission is how the shifter and rod is setup and also the bell housing and starter setup.
Here are the pictures:
DETurbine
Car: S13 RB25
oh also...before anyone askes....that is Redline lightweight and is the reason for it being blue.
krayton
DETurbine wrote:oh also...before anyone askes....that is Redline lightweight and is the reason for it being blue.
im pretty sure thats smurf jizz.
awesome research though. i think my 3rd is gonna give soon, so this is good news.
keep it up!
gawdzilla
Car: none
very cool research/work....
when you say 300zx, you mean 300zx NA right? not TT? or are they internally the same
DETurbine
Car: S13 RB25
I was comparing the transmission with the TT version, but I am pretty positive that both the NA and TT are the same internally. Here goes the link to the transmission service manual:http://300zx-twinturbo.com/cgi-bin/manual.cgi
scottsi
wow thats great, so when our trannies go out we dont have to source another rb25det transmission, we can just get a z32 transmission and pull the casings off and swap the rb25det casings on, z32 trannies are only about 400 -600 bucks
Dano
Car: '05 Nismo Frontier CC / '95 240sx base
if that can be confirmed, that's FAQ material right there.
-Dan
eh?
without the jizz
sean8564
Car: 1993 GTR Vspec, 1991 300zx TT Black , 1993 Nissan Silvia, 1990 Nissan 240sx Coupe RB25DET
scottsi wrote:wow thats great, so when our trannies go out we dont have to source another rb25det transmission, we can just get a z32 transmission and pull the casings off and swap the rb25det casings on, z32 trannies are only about 400 -600 bucks
So are Rb25 trannies
krayton
sean8564 wrote:So are Rb25 trannies
really? where at?
sean8564
I have 2 Rb25 trannies on my container for 600 each.But good info cause I will be rebilding mine in Jan 2 gear syncro
Kansei240sx
Car: S13 - RB25 Circuit car
71 240z - street/track day car
AE86 - Daily Drizzle/track day car
Z31t - Paper weight/street car
Thats some good work there guy, Have you any info on the speed sensor, or does anyone know? I've been trying to get a speed sensor for my RB25DET, and i dont know what will fit it, i know KA and SR's dont work becuase they arent long enough ( or so i've been told) If the z and rb trannies are so similar internally, will the Speed sensor off the z32 work?
Kansei240sx
bump, anyone know?
Dramier
Car: 76 Datsun 280Z
Well, I don't know about the RB25 trannies, but I'm about to try a Z31 VSS cable in an RB20 transmission... heh...
I'm using an RB25DE cluster with that.
(Damn, I really have a bastardized car!)
HxC_Nismo
Car: '98 Nissan 240SX SE R33 RB26DET
'07 Nissan Titan SE
'05 Toyota Corolla
i know this is an old thread but i just pulled my rb26 transmission apart tonite and the gear set looks identical too ill get pics up here in little bit, but im using my 26 transmission internal parts to rebuild my rb25det transmission (my 3-4 shift fork broke).
HxC_Nismo
'07 Nissan Titan SE
'05 Toyota Corolla
heres my rb26dett transmission gear set that i just took apart tonite and they look the same compared to your rb25det gear set. so for those of you that still have your rb26 transmission still keep em cause you can use parts off the gear set on your rb25det transmission.my car as it sits awaiting rebuilt transmission
az240wanted
Yes the speed senor off a z32 will work for the rb25 transmission. hybridz.org is a very good place to find info on rb engines. And I could be wrong but if I remember correctly the N/A z32 transmission is the same (internally) as the rb20 transmission and the tt z32 transmission is the same (internally) as the rb 25 transmission.
74260zt
Car: rb26powered early 74 260z car
az240wanted wrote:Yes the speed senor off a z32 will work for the rb25 transmission. hybridz.org is a very good place to find info on rb engines. And I could be wrong but if I remember correctly the N/A z32 transmission is the same (internally) as the rb20 transmission and the tt z32 transmission is the same (internally) as the rb 25 transmission.
Nope.... incorrect!! the N/A and the TT Z32 internals are the same, and can be made to work in the rb25det transmission.
The rb20 internals will not interchange with the above....
j.
240z4u
Car: '95 Nissan 240SX
j.
I can confirm this, I did it a couple years ago. Also the the z31 turbo transmission will work as well (thats what I used).
Joel, this is Evan Purple240zt from hybridz.org ... I think you helped me figure if it would work at the time along with a few others.
Thanks
HxC_Nismo
'07 Nissan Titan SE
'05 Toyota Corolla
i have the gear set out of the rb25det transmission and found the broken shiftfork and ill have more pics up really soon.
Booztd 3
Car: 1990 Nissan 300ZX TT
HxC_Nismo wrote:i have the gear set out of the rb25det transmission and found the broken shiftfork and ill have more pics up really soon.
So you found one of these?
The RB25/26 and 300ZX NA/TT transmission are all the same internally, there is no differences.
The only differences are in the input shafts (marginal difference, like 1/8" at most) and the tail sections have different shifter setups.
Please see my post here for LOTS more information
zerothread?id=226812
HxC_Nismo
'07 Nissan Titan SE
'05 Toyota Corolla
yea but mine was a bit uglier lol and it was the 3-4 gear shiftfork.
Booztd 3
HxC_Nismo wrote:yea but mine was a bit uglier lol and it was the 3-4 gear shiftfork.
Thats what is pictured, its just hard to tell because it was from a camera phone
This is a common problem, and it will keep happening. A new one is around 40 bucks. I am in the process of having a billet one machined.
Would anyone else be interested in an upgraded 3/4 gear shift fork?
HxC_Nismo
'07 Nissan Titan SE
'05 Toyota Corolla
im interested how much? also how much stronger should it be compared to an oem shift fork?
Booztd 3
HxC_Nismo wrote:im interested how much? also how much stronger should it be compared to an oem shift fork?
I have no clue, I have just sent the fork out to be CAD, and then it has to go to a CNC guy who will tell me what its going to cost to have them reproduced
The stock ones are cast aluminum and very brittle
HxC_Nismo
'07 Nissan Titan SE
'05 Toyota Corolla
keep me posted cause im interested
Booztd 3
For future reference, if you guys using the RB25/RB26/300ZX transmission ever shift hard into 3rd or 4th and all of a sudden you lose those gears, you broke the 3/4 gear shifter fork. When taken apart, it'll look like this
mello88
Car: s13
great info & pictures in this thread thanks for sharing.
I hope I never have to disassemble my transmission, it doesn't look like fun at all!
BigPar
AH...you can JB Weld that!
Booztd 3
mello88 wrote:great info & pictures in this thread thanks for sharing.
Its really quite easy
If you have the transmission already out, the tools you need to get down to where I have pictured are:
1. 10mm Socket2. 12mm Socket3. 14mm Socket4. Magnet Tool5. A good pair of snap ring pliars6. Dowel Pin Tools7. Hammer
