Hi everyone I just needed help with a problem I have. I tried to install a short shifter in my rb25 gearbox on the weekend but as I was placing the shifter in something wrong must of happen. The shiffter went in pretty easy but as I was checking to see if I had all gears I only could get into gear 1 and 3. The other gears feel like there not there at all. I went to pull the shifter out but now it won't come out. I have tried everything it just won't come out.
I have tried pulling it out
Taping it out
And removing the 4 bolts from shifter housing and pulling it out all together. The stock shifter came out so easy. Need help as fast as possible.
Thanks you
