rb25 s14 - efan install?
the a3k
Car: 1996 Black S14 RB25
i had the rb25 in a s14 but then i bought a new shell and swapped everything over into the new one. i have 2 electric fans on the radiator and a thermostat in the lower radiator hose.
the fans have 2 wires each and the thermo has 1 wire and another ground wire.
what would be the easiest way to hook all these up? i searched already and most of the other post have relays and switches and stuff i dont need.
i just want the fans to kick on automatically as soon as the thermo gets hot enough. i forgot how it was spliced together on the other s14 i had but i know the plug right behind the passenger headlight was used (probably for power)
wiring is not my forte so if anyone could help, id appreciate it
thanks
the a3k
anyone?
http://youtu.be/xKAANNTIKNE?hd=1
first 2 wires are from the thermo in the lower radiator hose
then you have the plugs which were spliced into the fans/thermo
3rd are the 2 cables from the first fan
4th are the 2 cables from the second fan
the a3k
anyone?
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
You need to use relays to power the fans. They draw an assload of amperage and trying to run that current through a thermostat switch will burn it out. Think about picking up a Dif fan controller or something similar.
the a3k
can i use one of the stock relays or buy another one??
so then id have fans, the thermo switch, relay.
i want them to kick on automatically without a controller. it worked somehow in my other s14. a relay might have been used actually... i dont have a picture from the old bay unfortunately
mixeds14
Car: 240
I wonder if u could used the altima fans in s14 write up for this.. they hook up to the factory relays.. I run mine straight to a switch cause atm I work to much for me to drive my car a lot but when i turn them on I can hear the rpms drop a bit while its idling..
the a3k
i ordered a thermo switch kit from SPAL. they actually have really good and straightforward directions on their site as well
Darius
Any relay will work as long as it is rated for 30A. I spent the $10 at O'Reilly's and got a universal one.
the a3k
http://www.spalusa.com/store/main.aspx? ... item=185FH
i got that from spal. even though i already have the thermo switch, this kit came with it. they also have really simple instructions on how to set it up
Tenchuu
Car: 97 240
I had one FAL fan on mine. it melted fuse holders (without blowing fuses) and wiring. about 5 of them of varying sizes melted until i ended up with a large car audio blade type fused distribution block. i also burnt through a SPAL controller, which coincidentally they won't replace once they change models. i cannot stress enough that you need to relay isolate, and if possible draw off a power distribution block (run a chink of wire off the alternator up to wherever you mount it) so you won't burn through wiring and fuse holders like i did.
My power distribution block is like this one:
http://www.ebay.com/itm/EFX-Core-C-Bloc ... b2&vxp=mtr
I think i even have an extra somewhere.
