RB25 balancer measurements
tommey
Car: S13 ca18det
Hi, can anyone please take some measurements of their harmonic balancer?
I would like to know the inner diameter and the distance between where the balancer meets the timing sprocket to where the bolt meets the balancer.
Does this make any sense?
Thank you!
240z4u
Car: '95 Nissan 240SX
So you need the hole size that slides over the snout of the crank and the thickness of the balancer in the center?
I have a spare pulley on the shelf, I can measure it but I don't have machinists tools.
tommey
Car: S13 ca18det
Yes that is correct!
The measurements does not have to be on micrometer level, a normal caliper measurement is good enough :)
Thanks !
240z4u
It's going to be measured with a machinist ruler, I don't have calipers! Don't worry I am pretty accurate. Ill try to remember to do it tonight.
tommey
Car: S13 ca18det
Great!
Thanks!
240z4u
23mm "deep"
29.5 or 30mm sized centerbore
I am retarded, of course I have calipers. That's what I used.
tommey
Car: S13 ca18det
Great!
Thank you!
ska69
Car: 200sx s13 ca18det
tommey, any idea if it fits ca18?
240z4u
I have a spare balancer I would sell if you want it. PM me if you need one.
